Buying a evo 1
Old Aug 24, 2014 | 05:00 AM
super_slav's Avatar
Buying a evo 1
Hi everyone I am new to this forum and I am going to buy a evo, I am interested in the older models (1 thru to 5), I am currently looking at a evo 1 for sale, is there anything I need to know about them, I am having trouble deciding between the evo 1 and 4, if I need a new engine in the evo 1, will a newer 4g63 drop straight in? This is the evo 1 I am looking at.
http://www.carsales.com.au/private/d...?Cr=47&sdmvc=1
Old Aug 24, 2014 | 06:18 AM
94AWDcoupe's Avatar
the evo 4-9 engines are mounted on opposite side of engine compartment. they dont interchange with early engines. I have driven all ten years of evos and prefer the early version. it drives light and nimble. the cars got progressively heavier with each year and the engine stayed 2.0. weight is your enemy in a performance car. but that is just my opinion. they are all great cars to play with.
Old Aug 24, 2014 | 06:53 AM
spors's Avatar
I think evos 1 to 3 are all RHDs and did not have any LHD versions.
Old Aug 24, 2014 | 07:38 AM
super_slav's Avatar
How are the evo 1 to 3's engines compared to the later motors? How are their transmissions?
Old Aug 24, 2014 | 10:03 AM
RS200's Avatar
The engine in the 1 and 2 are more reliable than the 4 - the 5 is quite good too. The 3 had weak ring lands and the 4 had oiling/cooling issues.
Transmissions are good if you don't abuse them in the 1-3. The 5th gear has a common weak syncro problem, but everything else should be reliable at lower power levels.
Nothing major interchanges or bolts in from 3 to 4, as mentioned the orientation was flipped. The head is backwards but valve train stuff still works (other than cams), and the reciprocating assemblies are the same.
Old Aug 24, 2014 | 10:51 AM
StreetLethal's Avatar
I can't remember but wasn't there also core shift in the 1-4 models?
Old Aug 24, 2014 | 12:02 PM
RS200's Avatar
I've never heard of it in the 1-3.
Old Sep 4, 2014 | 10:42 PM
2fast2evo's Avatar
There's a lot of commonality with the mechanical components of the early Evos (1-3) and DSMs of the same time, plus there was also the Mirage/Summit that shared parts as well.
4dibbo123
Jan 28, 2014 04:15 AM
tsitalon1
32
Dec 23, 2009 01:46 AM
lancer1.6
Lancer Aftermarket Forced Induction Tech
Mar 6, 2006 07:13 AM
TKVK1
Jan 25, 2006 08:17 AM
