Light weight race batteries, impractical...
Old Sep 11, 2014 | 06:43 PM
  #46
TommiM's Avatar
Originally Posted by Grimgrak
No one ever weighs the weight of running a thick wire to the trunk. You ain't saving squat in weight in relocation.
A good quality 0 gauge power cable isnt terribly heavy. My theory on this is, lets say for the sake of argument, that 13 ft of 0 gauge power cable weighs 10 lbs. That 10 pounds is being dispersed evenly across the lowest part of the floor in the car, and mostly in the center between the 2 axles. I beleive this will promote better ballast in the evo than say, having those full 10 pounds out in the left front corner of the engine bay, up high.
With that said, if you take the weight of a oddysey pc680 and 13ft of 0 guage power cable, and say 2 ft of 2 gauge ground cable, your still less weight than the weight of the oem battery. I actually weighed this stuff, but it was years ago. I may have posted a thread on it on here, but I cant recall
Old Sep 12, 2014 | 01:05 AM
  #47
fafaforza's Avatar
Originally Posted by deylag
The one week duration sounds right. Parasitic drains can kill any battery. I have a lithium-iron SHORAI LFX36A3 battery that can output 540 CCA. The longest I went without killing the battery is one year. I did this by turning on the Evo and letting it idle for 10 mins every week.
You know there are more efficient ways of charging a battery than using gasoline to power a 2 liter engine only to (among a host of other things) spin up the generator coil.
Just get a $40 battery tender.
Old Sep 12, 2014 | 06:18 AM
  #48
NJ9MR's Avatar
FCOTM Winner
My 21 pound Braille Battery (mounted in trunk) can last just over 2 weeks without starting up the car during Winter storage. I keep a Craftsmen Battery stabilizer/charger on it on for about 5 hours a week, and it's perfect! And, it's 3 years old. I'll never go back to a big, heavy, bulky battery.
Old Sep 12, 2014 | 07:18 AM
  #49
wowzers's Avatar
Originally Posted by NSDQ
Exactly. Small battery, light wheels, passenger and rear seats removed, spare tire removed, lighter weight engine mounts and suspension components. That stuff for sure adds up.
i guess race batteries are really meant for what the name suggests.
when it comes to competing against the clock… even if you were to save weight on 1 bolt.. you will remove for the race.
let alone getting rid of a bulky big heavy conventional battery
Old Sep 12, 2014 | 08:05 AM
  #50
NSDQ's Avatar
Well said sir
Old Sep 23, 2014 | 02:28 PM
  #51
kyoo's Avatar
Lol I have full interior and still have the spare tire in the trunk, 7" screen in the dash and the A/C, while not working, is still hooked up. I'm not concerned about reducing weight at the moment. It's pointless to run a small battery, IMO, if not doing any other significant weight savings. Weight balance, however, is a different story.
i'm in a similar spot with this guy. this and i'm paranoid about enough charge getting to the fuel pump etc.
Maybe an "upgraded" miata battery isn't a bad idea, i.e.,
Amazon.com: Optima Batteries 8073-167-FFP D51R YellowTop Dual Purpose Battery: Automotive Amazon.com: Optima Batteries 8073-167-FFP D51R YellowTop Dual Purpose Battery: Automotive
saves 13lbs over stock at least? thoughts?
Old Sep 23, 2014 | 03:11 PM
  #52
NSDQ's Avatar
For me, personally, I'm going to stay the course with my current interior, battery, and weight of the car until I get some track times to show me where I'm at. I'm going to compare my track time(s) to those in the fastest times thread in the drag forum plus weigh my car as it sits once I get it back from Fathouse. If I'm in the low 11's, like an 11.1, then I'll probably look to improve driver mod and reduce some weight and get into the 10's. If I run in the 10's, I'll probably keep my interior where it's at. A 10sec street car with full interior and body trim, to me, is where I'd love to be.
Old Sep 23, 2014 | 03:19 PM
  #53
sujinX's Avatar
im running the 51r battery, been doing so for a while, no problems at all. about 11-13 lbs is a lot off the front, daily driven all year around. i think the miata batteries are a tad cheaper than the honda batts.
Old Sep 23, 2014 | 09:54 PM
  #54
kyoo's Avatar
good to know - no issues at all i gather? what's the longest you've got without starting the car up?
94AWDcoupe
44
Nov 6, 2017 08:40 AM
mrevo10
Sep 6, 2016 12:36 AM
Jax419
21
Apr 1, 2016 03:31 PM
DaEvoPusha
Oct 15, 2015 01:09 PM
blk-majik
24
Jul 24, 2015 12:10 PM
