driver side window
Old Sep 7, 2014 | 01:59 PM
Tadt's Avatar
driver side window
Hey guys!
im having an issue with my driver side window not going down. doesn't make any noise just wont go down. also from the driver side i cant get the passenger window to go down either but the passenger can put his window down and up no problem
not sure if it could just be a loose wire or bad connection any thoughts?
Old Sep 13, 2014 | 07:09 AM
Jgren's Avatar
check to see if you have power getting to the switch. also I've come across this in other cars, the wires in the door jam eventually break from being bent over and over again.
Old Sep 14, 2014 | 07:02 PM
EatSleepBoost's Avatar
+1. What about the rear windows? Do they also not operate from the master switch but they seem ok from their own door panel switches? If so you lost power or ground to your master switch or the switch is bad.
Old Sep 23, 2014 | 08:47 AM
Tadt's Avatar
sorry my comp broke and couldn't get online to reply...
But yes both back windows work fine with the driver controller. but my back windows do go down sometimes a half inch to a inch or even all the way down on my cold starts when i dont fully turn over. sometimes ill hit the button for them to close but they will only go up a few inches before automatically going back down again... winters coming and this needs to get fixed.
Wicked_Ray
Sep 24, 2015 06:23 AM
pkolaboy
Lancer Troubleshooting
13
Jul 13, 2014 08:39 PM
EvoGSR8
Mar 10, 2014 02:19 PM
Grungy
May 17, 2013 09:52 AM
GgreyEVOIX
May 23, 2012 07:24 PM
