Dip stick tube affects oil pressure??
Old Sep 8, 2014 | 09:11 PM
sbannister14's Avatar
Thumbs up Dip stick tube affects oil pressure??
having problem with my evo 8 oil pressure. just did a motor swap and is stock for the most part now... for now. but at idle oil light tries to come on. i have a slight hole in my dip stick tube about 6 inches from the block. Damaged during shipping. my question is does that have any effect on oil pressure? just trying to cross off the less expensive things first. Thanks stephen!
Old Sep 9, 2014 | 05:30 AM
EatSleepBoost's Avatar
No. Dipstick does not matter. You need the oil pressure switch on the back of the block most likely. I have done them on both of my evos and everyone I know who has had an evo has done theirs as well. Mine started to flicker after installing cams. Replaced it, never seen the light since.
Old Sep 9, 2014 | 05:53 AM
whatever210's Avatar
or bad oil pump?
Old Sep 9, 2014 | 08:34 AM
possible. i was hoping its not bearings. but a switch sounds cheaper. I'm just trying to slim the list down of what it could be to a possible culprit.
Old Sep 9, 2014 | 08:41 AM
search for oil light. Very common. Here is one thread example https://www.evolutionm.net/forums/ev...d-problem.html
Old Sep 9, 2014 | 08:42 AM
could it have anything to do with the lifters?
o3evo8
Apr 26, 2017 03:59 PM
EVOEvolved
Jun 19, 2016 03:06 PM
maknuge
Oct 20, 2015 01:07 PM
tweakers-r-us
May 19, 2015 08:19 PM
LetItBreath
31
May 5, 2006 11:49 AM
