Pulled code
Old Mar 13, 2004 | 12:33 PM
SouthernCrane's Avatar
Pulled code: Please Help
Anyone know what P0243 is? I couldn't find out what it was after it was pulled. Thanks in advance.
Old Mar 13, 2004 | 12:52 PM
CLeeEvo's Avatar
P0243 Turbocharger Wastegate Solenoid Circuit
Old Mar 13, 2004 | 01:13 PM
Thx very much CLeeEvo.
Old Mar 13, 2004 | 02:19 PM
CLeeEvo's Avatar
No problem. Hope you can fix it.
Old Mar 13, 2004 | 03:24 PM
EVOMIZ's Avatar
I am getting the same code let me know how you fixed it
Old Mar 13, 2004 | 07:17 PM
I think the problem lies in the vaccum line that leads from the T fitting to the wastegate solenoid. I accidentally put a hole in it i think, but maybe my solenoid is malfunctioning. Right now my car is only boosting 12 lbs, i think the hole is bleeding off some of the air.
Old Mar 14, 2004 | 09:56 AM
CLeeEvo's Avatar
How did you put a hole in it?
Old Mar 15, 2004 | 12:15 PM
kam's Avatar
kam
Has anyone found an answer to this problem?
Old Mar 15, 2004 | 01:06 PM
mitsuorder's Avatar
Not relying on the pos stock boos solenoid for control would be a good step, not bashing here but omg that thing began malfunctioning within the first 4 or 5 months of me owning the car.
Kam how's everything going man? I was in Houston for the weekend for a funeral, wish I could have had time to meet up with ya.
Old Mar 15, 2004 | 01:08 PM
1QWKEVO's Avatar
have any of you guys disconnected your stock boost solinoid after installing a boost controller, if so theres your problem... the solinoid needs to remained pluged into the harness or the ecu will throw a code
Old Mar 15, 2004 | 01:12 PM
MalibuJack's Avatar
Well, disconnecting the hose alltogether will cause overboosting, so cutting a hole in it would probably result in high boost.. if its plugged, it will boost at or near 10psi since that will provide the full signal to the wastegate..
Usually that code results from the solenoid wire being disconnected.. probably a good idea to disconnect the cable and plug it in again just to make sure its seated ok.
Old Mar 15, 2004 | 07:46 PM
kam's Avatar
kam
What's up mitsuorder? You have my condolences.
So, you had problems with the stock boost solenoid early on. Did you have low boosting problems? What did you do to fix the problem? Did you go to a manual boost controler or replace the solenoid?
This should be in tech.
Old Mar 16, 2004 | 08:55 PM
Got the vaccum line replaced and reset the ECU and now I am getting full boost again. everything seems to be working okay.
Old Mar 17, 2004 | 01:45 PM
DB8GSR's Avatar
Glad to hear that Bryan!!
Old May 27, 2006 | 02:25 PM
theEVOdream's Avatar
thx! you hopefully solved my problem! I installed a hallman MBC and didn't leave the stock bcs plugged in with caps for the tee's. Lets see if I can get rid of this pesky code....
EVO IXMR
Mar 8, 2011 06:05 AM
romanian
11
Jan 5, 2010 06:45 AM
Anarchy08
Jul 24, 2008 08:10 PM
importjake00
Jan 23, 2008 10:08 AM
cityhugo
24
Jan 12, 2004 07:23 PM
