Haven't Modded my Evo for 4 years... What's new since then?
Hey everyone,
So, I bought my IX new in 2006 and put a few mods on it. Since 2009, I have just been daily driving the car and enjoying it. But that recently changed when I installed an ETS 3.5" intercooler on the car. Now, I've got the taste of modding again.
So, I've got 2 questions:
1. Back in 2009, I was tuned by Tobz out here in the Denver Colorado area. Does anyone know who the reputable tuners are out here now? Any suggestions?
2. Back in 2009, the CBRD BBK full was the stock frame turbo of choice for a daily driver. Is that still the case, or is there another, newer, turbo out there that performs better.
Thanks for your input and it's good to be back!
1 Post
FP recently came out with some sick turbos with a stainless steel o2 housing which is nice because you can run external wastegate and dump but you will also need a new downpipe but you can use the OEM style manifold.
oct 10 2009 tehpramod v7 came out. Its a free custom rom that adds a whole mess of really nice things to the stock ECU. Adding features that you usually need a stand alone to get. Some examples are launch maps, Gear dependent boost control, AFR safety monitoring, Valet mode, etc etc. There are also Speed density versions of the roms so you can convert your car to run SD still using the stock computer. Its worth checking out over on the ecuflash subforum.
Thanks for the reply, you guys.
Slowsrt4: Are the new turbos you're talking about the FP Zero and Zephyr? I read about those, but I don't want to go v-band. That being said, I heard that FP... or HTA... released a new stock frame turbo that is bolt-in. Do you have any more information on that?
Biggiesacks: Thanks for the info on tephramod v7. I started reading the thread on it and am still totally underwater! This topic should keep me busy for a LONG time.
As always, I'm interested in hearing people suggestions or experiences... especially with do-it-all turbos good for daily driving and the occasional HPDE or Auto-x.
the fp turbo you should look into if wanting to stick stock frame is the fp black. with the new o2 housing its hardly stock frame anymore, and with the price tag as well as needing a wg and new dp you may as well just go t3.
as far as tuners go, mellon racing went under, but has resurfaced, and i think went back under again because i have not heard from them recently. i would look into tcompuse.
Yeah, I been seeing stuff about "stanced" evos with crazy offset wheels and a bunch of camber to clear them....
So, does anybody run smaller stock frame turbos anymore? Lately, it seems like most guys are running "big" stock frame turbos. I was looking at the FP Green, or the BBK-B. I don't drag race much, other than a for-fun test and tune night out at Bandimere. Really, I'm more into autocross and NASA HPDE. So, I want something that spools fast and I don't need a huge amount of power.
That's another thing... I got fuel injectors back in 2007. In those days, my 750cc injectors were considered large-ish and 1000cc injectors were HUGE and had drivability problems. I've noticed a lot of guys running injectors way bigger than that now. Has there been an improvement in technology so that you guys can run those big injectors without idle or daily drivability problems?
Thanks for all your input, by the way. I feel like I'm slowly catching up.
As far as stock frame turbos they are still very popular. I have the HTA green and love it. Spool is the same or maybe even better than stock since im 2.4L. Many people now do a fp green, red, or black. Then add some 1450cc injecors, fuel pump or double pumper. FMIC w/piping, intake and cams. If you go with a slightly aggressive cam (s2, s3) you can help out where the smaller turbo starts to die out up top. Depending on if you are on 93 or e85 this type of setup will put you in the 450hp range typically. Most people go past just the basic bolt ons now and do something like this. Still a pretty stockish car but way more power. Don't forget you will need a clutch to hold that power though.
