ABS BRAKING PROBLEM NEED HELP Evo7
Old Oct 13, 2014 | 09:16 PM
tuner21's Avatar
Hi guys,
Having few issues with my abs system on my evo7, Abs light turns on with ignition and turns off once car starts
Scanned it today and comes up with following codes
11 FR sensor open
12 FL sensor open
21 FR senor fail
32 G sensor
71 G S (lateral)
Im only able to read code unable to clear for some odd reason. Anyone has come across these problems?? Any help will be much appreciated.
Old Oct 14, 2014 | 10:32 AM
GTijoejoe's Avatar
Originally Posted by tuner21
Hi guys,
11 FR sensor open
12 FL sensor open
21 FR senor fail
32 G sensor
71 G S (lateral)
All those errors? Its unlikely they all the parts have failed at the same time, I'm going to put my money on the modulator ECU, its the brain of that system.
You probably need a new modulator.
Old Oct 15, 2014 | 03:07 AM
tuner21's Avatar
done some more test today and looks like front abs sensors are faulty, no resistances. weird scanner still show speed signal. Also i cant seem to clear abs codes from system using scanner... is there any special way to do this?
Old Oct 15, 2014 | 04:57 AM
todd6027's Avatar
check the wiring connectors in the front footwell both sides behind the plastic kick panels
Old Oct 15, 2014 | 04:59 AM
todd6027's Avatar
Mark_Evo7
Aug 9, 2014 08:27 PM
bdonIX
Dec 18, 2012 02:22 AM
tyre11c0rp
Aug 26, 2008 06:22 AM
PoWeRaCeRz
Jan 27, 2004 09:40 PM
akinaspeedstars
Jan 14, 2004 09:36 PM
