Girodisc rotor problem help
Old Jan 2, 2015 | 02:20 PM
EvO-LOui's Avatar
So I just received my 2 pcs rotors front and rear for my 2006 lancer Evo. these are my second set on my second Evo . I'm having a problem with them .I just installed them and I'm getting a clunking noise as I press on the brake pedal car stops properly. now I had no problem with the first set I installed on my Evo only difference is I'm running the magic pads this time around on my last set I used ferodo 2500 pads an trimmed the rear pads for Clarence and I use the shims. so I'm pretty much at a dead end on what it could be I'm using magic pads which already come with the shims or am I require to buy additional shims?not sure what else I rechecked everything once again everything looks fine what could it be ?
Old Jan 5, 2015 | 06:43 AM
EvO-LOui's Avatar
Problem fixed 👍👍
Old Jan 7, 2015 | 08:25 PM
whiteEvo08Y's Avatar
Originally Posted by EvO-LOui
Problem fixed 👍👍
What was the problem?
Old Feb 2, 2015 | 06:50 PM
EvO-LOui's Avatar
Originally Posted by e_kobz
What was the issue?
Simple fix just need to bond the pad on to the rotor . on normal stops noise went away as I use it more .it's a own issues at giro disc mike at giro disc was very helpful
EVOlutionary
90
Feb 8, 2016 09:45 PM
Girodisc Martin
Evo 'For Sale' Suspension / Brakes / Handling
40
Oct 11, 2013 09:40 AM
Girodisc Martin
37
Jun 11, 2008 09:02 AM
Girodisc Martin
Dec 28, 2007 10:23 AM
