boost wont pass 14 psi
Old Feb 4, 2015 | 11:48 AM
  #31
ekinshuya's Avatar
yea i dont know how much it was boosting before since i didnt have a gauge before then and there is no pending or overdue maintaince. ill try get it a boost test when i can.
wondering if i would peak to 18 or 19 when i get back to sea level lol
Old Feb 4, 2015 | 12:32 PM
  #32
sparky's Avatar
Originally Posted by ekinshuya
ACTUALLY ITS 15 PSI that it wont go pass...AT 4th gear 2,500rpm full gas throttle to 6,000 RPM....but not getting the 18 or 19. could it be elevation?....its at night at 39 degree F so could it be elevation and cold weather?
FYI, each 10* F. change in ambient air temp results in a 1 PSI change in manifold boost pressure. So, if daytime ambient air temps are let's say 69* F. and your gauge reads 12 PSI, and you take the same car out at night when ambient air temps are 39*, your boost gauge will read 15 PSI.
Old Feb 4, 2015 | 02:44 PM
  #33
ekinshuya's Avatar
i think it was the same temp in the morning too since its winter snow season here in colorado
Old Feb 5, 2015 | 10:10 PM
  #34
ekinshuya's Avatar
i talked to the dealer and they said they will do boost leak test for $115 and that will go toward the price for repair too if there is something. The service advisor said could be a bad soleniod...anyone know how much a new boost solenoid cost? (stock one)
Old Feb 5, 2015 | 10:43 PM
  #35
slvrevo84's Avatar
im sure you could find a used one on here someone took off for pretty cheap.
or its $65 for a new oem one.
Old Feb 5, 2015 | 11:59 PM
  #36
Teal2nnr's Avatar
Boost leak tests are pretty easy to do. So you cant raise the boost at the moment?
Old Feb 6, 2015 | 07:40 PM
  #37
ekinshuya's Avatar
Not more than 15 psi
Old Feb 6, 2015 | 07:41 PM
  #38
ekinshuya's Avatar
I might get a Hallman manual boost controller. It would be fine to set 19 psi like stock boost if I don't get it tune?
Old Feb 7, 2015 | 11:58 AM
  #39
Evilution226's Avatar
Try taping on the WG solenoid and the arm with the but end of a screwdriver, may be stuck. Have you tried to put air press. to the solenoid to see if it moves back and forth.
Old Feb 7, 2015 | 12:40 PM
  #40
FX11's Avatar
Boost leak test. Not sure if you have an AFR gauge. And check your WG
Old Feb 8, 2015 | 12:00 AM
  #41
ekinshuya's Avatar
not sure how to do this exactly. could u be more specific?
  #42
ekinshuya's Avatar
not done boost leak test or check WG yet but my aem afr reads fine
Fast-Mover
43
Sep 30, 2008 01:39 PM
DynoFlash
15
Aug 23, 2007 04:57 PM
03redtype-s
Sep 4, 2006 01:47 PM
Mooshu1221
15
Jan 6, 2005 06:43 PM
