03 Evo 8 not starting, but I have done some diagnosis
Old Mar 13, 2015 | 11:24 AM
tarheelsoldier's Avatar
Ok, The car won't start or if I give it gas, won't stay running. The EGR Vacuum Solenoid had 2 of the vacuum lines broke off so I replaced that. The front O2 has been replaced due to being the only code that was on. I checked the IAC by unplugging it. All it did was spit and sputter and misfire like hell. Almost like it was labored to run. I have tightened up almost every clamp on the turbo and intercooler system. Any ideas?
Old Mar 13, 2015 | 01:34 PM
Ev0ikon's Avatar
Did you test for boost leak?
Old Mar 13, 2015 | 04:25 PM
xPSYCHOxWHITEx's Avatar
do you have the injector resistor bypassed?
Old Mar 14, 2015 | 07:15 AM
I did some more tests. Found a couple more leaks. So I got them fixed. Now. It's back to not starting to when it is warm. Idles fine and runs great cold, but once it warms up... it does the same thing as before. I did the iac check again and it doesn't appear to be that. And I don't have the injector resistor passed to my knowledge.
Old Mar 14, 2015 | 09:58 PM
Ryan4dc's Avatar
Got a generic scan tool? Could be coolant temp sensor. Check it before replacement.
Old Mar 15, 2015 | 05:05 AM
I actually ran by a shop yesterday. They turned the boost down and fixed it. The previous owner had it set at 22 lbs. Dripped it to 20 and it was fixed. Apparently there is no tune on the computer.
2006evolutionse
Mar 23, 2015 12:59 PM
PistenBoy
Jul 16, 2013 04:51 PM
05VIII
64
Jan 25, 2011 12:13 PM
bigben
Dec 21, 2010 08:02 AM
migs647
Northwest Region
18
Sep 12, 2008 01:24 PM
