Instrument cluster wire diagram...
Old Mar 16, 2015 | 06:59 PM
black_beauty's Avatar
My right turn in the gauge cluster does not work, I replaced the bulb with a known working one and nothing. So I'm trying to see if I have current coming into the cluster at the connector. Need to know which wire to check and how much voltage to check for. Ive searched but turned up nothing useful. Any help is appreciated. Thanks.
Old Mar 17, 2015 | 05:04 AM
Ausevo7's Avatar
i had a look through the workshop manual and i think this might help you. if it doesnt let me know i'll keep looking. You want to look at the far right of the image. i believe right turn signal is pink and left is light green[IMG][/IMG]
Old Mar 17, 2015 | 10:51 AM
and what should I set my multimeter at to check? Thanks!
Old Mar 17, 2015 | 07:17 PM
Ausevo7's Avatar
You should set your multimeter to 12volts dc.
You wont pick up any amperage as there is no light globe connected in the dash to draw current.
Old Mar 17, 2015 | 07:47 PM
Heavy1976's Avatar
You may have the globe in the incorrect position.
Old Mar 23, 2015 | 05:14 AM
bulbs have been rotated 180* as I thought that as well using the LEDS I replaced them with, but still nothing.
Old Mar 23, 2015 | 05:23 AM
Ausevo7's Avatar
are you picking up any voltage at the cluster?
are your turn signals on the out side of the car work?
when you push the hazard button do both lights in the cluster work or just the left one?
when you turn your right turn signal on do you hear the relay clicking?
sorry for the many questions im just trying to narrow down the search to a certain area if i can.
Old Mar 23, 2015 | 05:26 AM
Ausevo7's Avatar
standard halogens are not polarity sensitive and should work either way you put them in. LED's can be polarity sensitive, installing the LED's the wrong way ( if those LED's are polarity sensitive ) will blow the LED itself.
Old Mar 31, 2015 | 05:24 PM
Ausevo7, the right turn works as it should outside the car, hazard only shows the left side on the cluster, the relay is clicking. Im having a hard time seeing voltage at the pink wire, does it have to be plugged into the cluster perhaps?
Old Mar 31, 2015 | 07:23 PM
Ausevo7's Avatar
If the relay is clicking than at the cluster you should see the voltage go like this 12volt- 0 volt - 12volt - 0 volt.
If your not getting voltage at the pink wire, id suggest tracing it back to the correct relay and see if the relay is operating correctly.
if you are getting voltage at the relay, the only other thing i can think of would be a break in the cable somewhere or even a dry solder connection on the instrument cluster.
Old Mar 31, 2015 | 07:30 PM
Ausevo7's Avatar
Oh and you will see voltage even with out the globe connected, you'll only need the globe in to measure current/amperage
Old Apr 3, 2015 | 04:03 PM
I'll check it out, the hunt continues!
McRooster
Jan 7, 2018 08:51 PM
allday10sec
May 27, 2009 11:36 PM
Barse
Lancer Troubleshooting
11
Aug 17, 2002 12:23 PM
