Clutch Disengaging Issue
06 MR
Exedy Twin HD
Problem:
-while vehicle in neutral, letting off clutch pedal engages clutch when not in gear. (normally this shouldn't happen, it shouldn't add any load to the engine, or cause any friction if in neutral)
Tried:
-bleeding clutch
-adjusting clutch pedal under dash.
Resolution: ??
looking for some help, the engine has just been installed and I've barely driven the car because of this, it didn't do this when i took the engine out.
Exedy Twin HD
Problem:
Tried:
-bleeding clutch
Resolution: ??
So your engine load is changing when you release the clutch? What friction are you talking about? Is the clutch dragging?
to make sure they're not in gear
the clutch is always engaged when you let off the pedal. the only thing making you move forward would be if gears are engaging, which in neutral they won't
did you do anything to the transmission?
if you didnt, then it "shouldnt" be since it didnt do it before hand.
just checking, your not pumping the clutch pedal when you bleed right?
have you tried shifting into different gears? any binding issues etc? shift linkage in wrong way?
Boost3dxEvO
Aug 25, 2009 07:15 PM
Boost3dxEvO
Automotosports - Illinois
Aug 17, 2009 02:51 PM
petersa9
26
Feb 19, 2005 08:56 AM
