Anyone DD with ACD flash?
Old Apr 28, 2015 | 07:22 PM
buzzzin_IX's Avatar
Like the title says, anyone here on the forums DD their evo with the ACD flash with no mods to their Diff? State who you got your flash from. How much better does the car handle?
Old Apr 29, 2015 | 07:41 AM
alleggerita's Avatar
If I could have done only one mod on the car this would be it.
No downsides for DD whatsoever with no other mods. With a TRE rear diff I occasionally switch to gravel or snow in tight parking lots to decrease lock-up.
https://www.evolutionm.net/forums/ev...ni-review.html
ACD tuning is no longer in business and took a bunch of people for a ride at the end but other vendors are:
http://www.shopenglishracing.com/Eng...CD-Tuning.html
https://www.evolutionm.net/forums/ev...acd-flash.html
Old Apr 29, 2015 | 06:27 PM
hearnoevo's Avatar
acd
I bought mine from English Racing. I sent them the ACD Ecu then they reprogrammed it and sent it back to me. Keep in mind that if you DD your car and you are driving at slower speeds you could get some vibration when you turn the wheel.
To remedy this, I asked Aaron to keep the tarmac setting the same as stock. Whenever I want to bang the corners, I switch it to snow mode. When I hit traffic or want to drive at normal speeds again I switch it back to tarmac mode. This is the best way to set up the ACD ecu in my opinion.
Mine is available for purchase if you're interested, just pm me.
Old Apr 29, 2015 | 08:08 PM
buzzzin_IX's Avatar
Was your stock diff noisy with tune? i read in your thread that with the TRE it was noisy at first the quieted down. How is it cruising around town?
Old Apr 29, 2015 | 08:09 PM
buzzzin_IX's Avatar
Do you have stock diff with the tune? i will keep you in mind when i decide to make a move on it! deciding weather or not i should get a TRE diff as well.
Old Apr 29, 2015 | 08:44 PM
No noise or vibration whatsoever from the flash alone.
Initial noise from TRE diff that is completely gone after break-in.
Slight tire scrub from TRE rear diff in tight parking lots. Can be dealt with by switching to a less aggressive map.
I wouldn't want to drive any Evo with a stock map anymore no matter what conditions ... IMO stock ACD map totally sucks and spoils what is otherwise a brilliant car.
Old Apr 29, 2015 | 08:46 PM
buzzzin_IX's Avatar
how long have you had the tune? any problems with it over working the acd pump? mann you make me wanna make the switch right now! but funds are alittle tight. i want to get the TRE diff as well.
Old Apr 30, 2015 | 05:38 PM
Had the ACD tune since spring 2012.
I wouldn't be concerned about overcycling the pump. It's more likely to die from corrosion.
TS comp has a 6-map flash on sale right now. Can't comment on the quality of their maps but you should be able to find something among 6 that is better than stock.
The tunes seem to be very different from vendor to vendor depending how people set them up. But I would go so far as saying nothing is likely worse than stock. In my case it was absolute magic ...
Old Apr 30, 2015 | 06:03 PM
buzzzin_IX's Avatar
thanks for your help!!, im trying to get in contact with one of the other members here that has the english racing ecu forsale. Would be nice to have both stock and flashed ecu just incase!
Old Apr 30, 2015 | 07:09 PM
Thrilla's Avatar
Veteran: Army
I had the Gruppe-S flashed ACD for a few years. They were one of the first to offer the service, but I don't think their maps are as aggressive as the other newer ones. Not much different driving around on the street. Slight improvement in a road course, but it did not fix the understeer the platform is known for. This season, I've upgraded to a Sheptrans rear diff, and noticed an improvement with turn in right away. I haven't taken it to a road course yet, but hopefully soon.
If I was to do it all over again, I would upgrade the rear diff first (re-stack, shep, or TRE) and only if it's lacking, flash the ACD.
Old Apr 30, 2015 | 07:22 PM
sssr20det510's Avatar
I believe they leave the stock 3 maps and add 3 new maps so u still have the stock ones u could use.
Old Apr 30, 2015 | 07:48 PM
Go_Lancer_Go's Avatar
Nope thats not true.
Old Apr 30, 2015 | 08:06 PM
This is what ts comp said when I asked
For now, there are just 3 stock settings for the person to use factory settings, then there are 3 additional modified more aggressive settings.
We can of course, tune all 6 maps however.
Old Apr 30, 2015 | 08:18 PM
hearnoevo's Avatar
acd
Yes, stock diff with the tune. I'm sure it would feel even better with an upgraded differential.
That is with a different company. English racing only uses the three modes when flashing the acd.
Old Apr 30, 2015 | 08:35 PM
Oh I didn't realize english wasn't a 6 map flash like tscomp
06MREvo
For Sale - Part Outs
34
Nov 18, 2014 01:05 PM
NOMIEZVR4
Oct 18, 2013 01:28 PM
DubsE46
Sep 11, 2012 12:03 AM
DubsE46
10
Dec 30, 2011 04:48 PM
