why is my new tial q bov not working
Old May 20, 2015 | 07:59 PM
oneslow-evo's Avatar
hey everyone, this my 1st post on this forum. Well actually any evo forum. I recently bought my first evo. A
White 03 evo8 with 75k miles. I bought it with a nock off hks ssqv that only fluttered/surged and cheap piping. I purchased a used ets upic pipe with a tial bov flange for a good price. I bought a tial q with 11psi spring from extremepsi.com, after Installing everything the tial just fluttered/surging in any boost. I tried a 8 psi spring to and it did the same and actually didn't let me go past 4500 rpm so I put the 11psi back in. It was fed from a T that went to the boost controller and intake mani. So i tapped the compressor housing with a banjo bolt and 1/4" nipple and used good solid fuel hose. It kinda works but still flutters/surges. Next I was going to test the ic piping for any boost leaks.
ANY OTHER IDEAS
stock motor with hks 272 and Aftermarket gears.
bigger front mount and j pipe
Vacuum at idle is roughly at -10
Old May 20, 2015 | 08:11 PM
Tekniq's Avatar
https://www.evolutionm.net/forums/ev...tall-help.html
Old May 21, 2015 | 04:48 AM
This is how i have it. Their shouldn't be any problem with it getting proper Vacuum, I think.
and the vacume hose in the picture is replaced with FI fuel hose 1/4 inch
Old May 21, 2015 | 06:49 AM
idkmybffjjill's Avatar
From that thread that was linked:
THe vacuum line is suppose to go behind the throttle body like in the above pic. You just need to move your vacuum line to the intake manifold and everything will work fine.
Old May 21, 2015 | 08:17 AM
flicker's Avatar
The BOV has to see a vacuum source to work. You will not see vacuum pre-throttle body so the vacuum hose must attach to the intake manifold.
Old May 21, 2015 | 10:19 AM
LetsGetThisDone's Avatar
Yea, the BOV needs a 1/4" vacuum source off the manifold..
Old May 21, 2015 | 07:10 PM
MRolla's Avatar
Epic fail.
Old May 23, 2015 | 12:11 AM
AceCampano's Avatar
LMFAO... bruh..
Old May 23, 2015 | 12:41 PM
Lol I thought it just needed any vacume sorce.
can I run a boost controller off it?
Old May 23, 2015 | 01:24 PM
enjoiskater7788's Avatar
It does need a vaccum source the compressor housing is not a vaccum source..
Old May 25, 2015 | 05:32 PM
egis's Avatar
Yes you can but you have one on the J pipe. Either one needs to be plugged or connect them together.
Old May 25, 2015 | 07:06 PM
lostsoulsevo's Avatar
I'm sorry OP, but I about died laughing!!! The bov should have its own vacuum source off of the intake manifold.
Old May 26, 2015 | 05:34 AM
Tekniq's Avatar
https://www.evolutionm.net/forums/ev...procedure.html
Old May 26, 2015 | 10:51 AM
DSMolition's Avatar
Not even one VTA comment?!?!
FlaEvolution
13
Jun 21, 2012 09:37 AM
turboDan
May 8, 2006 01:52 PM
turboDan
Mar 21, 2006 07:26 AM
Dasneak MR
Feb 14, 2006 04:37 PM
Ralli04Art
Dec 15, 2005 06:24 AM
