Rear wheels locked ???
hello Evom...
Im looking for a little help on what is causing this problem...
I got into a bad car accident with my older brother last april 2014 . he pass-away in the accident and i somehow lived... but on to the problem/car 2003 evo 8 .. 160,*** miles the clutch was slipping so i parked it and it has been sitting for a year... went to move it and it will not move so i had some friends help me push it. The Drivers side back wheel will not turn . so i jacked up the car and both back wheels do not spin they only move about 1/2in . IS the rear diff shot?
Thanks for any help you can provide
rear brakes are frozen?. its moves about a 1/2in the back tires... brakes are not stooping it. Drive shaft spins while spinning the front tires manually just not the back ones... any tips ..
If you've left it parked for a year, and for some reason you didn't decide to drain your rear differential completely dry, you most likely have either issues with your rear brake pad/rotor mating surface, or the parking brake shoe/hat mating surface. Have you pulled the rotor yet and tried to rotate the hub?
Front Diff problem?
Hey guys, I might be on the wrong thread but I have a problem with, I believe, the front diff. I hear a really loud grinding noise when I put my car into gear. And the car doesn't move too. I don't know for sure if it's the diff or singing in the transmission or the clutch. Help would be appreciated.
clip14
Jul 1, 2015 01:43 PM
manni_t5488
For Sale - Part Outs
31
May 15, 2011 08:35 AM
QwikEVO
12
Sep 22, 2007 04:38 PM
