best blow off whats best ?
Old Jun 27, 2015 | 11:45 AM
  #31
kaj's Avatar
kaj
Originally Posted by Dave123456789
Also I like keeping my boost in my intake pipes between changes instead of throwing it into space
LOL how did I miss this piece of wisdom?
Old Jun 27, 2015 | 03:49 PM
  #32
Dave123456789's Avatar
Originally Posted by sparky
Wow. For sure. "Bold as Love"
What's the suppose to mean? Not going to argue I am just stating my own real world experience.
Old Jun 27, 2015 | 03:59 PM
  #33
Originally Posted by kaj
That flutter is the sound of your turbine crying for help (pressure build up/forced release of BOV over and over). You're slamming the door shut on a compressor that is moving enough CFM to create 25psi of pressure at high RPM.
I have an old, snapped CHRA to prove it.
It sounded great until the turbo died LOL. When I checked the DV, I found the nipple bent down, not really allowing the valve to vent. Muh bad. LOL
I would highly suggest tuning your valve properly. Just my opinion, though.
I have removed the bov so it's definitely not the sound of a bov fluttering now. The turbo barely slows down, might get a tiny bit of side loading but your getting that anyway when your throwing pressure in a pipe.
And shafts snap all the time for many reason. How can you be sure? I could easy point you to some examples of shafts snapping in cars with bovs. Does that mean running a bov snaps shafts too?
Anyway enough of this debate. Debating over the Internet is pointless. Only one disadvantage of running no bov is crusing throttle sensitivity, if you say press the gas a tiny bit to speed up then back your foot off the gas it can be a tiny bit jerky. Most of time I can barely notice it, passengers don't feel it only hear the vutututu sound.
I'm not saying go out there now and remove it but now if your considering it that's my experience
Old Jun 27, 2015 | 05:23 PM
  #34
kaj's Avatar
kaj
Then it's your wastegate being forced open. Do you understand why diverter valves are installed? It's because all that air is instantly stopped at the throttle body which stops your turbine and puts a great deal of force on it. The DV is there to save your parts and keep the turbo spinning and working as efficiently as possible.
Your post is....astonishing. I sincerely hope nobody takes your advice.
Who filled your head with this idea, anyway??
Even SuperStreet knows:
http://www.superstreetonline.com/how-to/engine/sstp-1211-blow-off-valves-explained/
Old Jun 27, 2015 | 06:31 PM
  #35
Um it's definitely not my waste gate being opened, do you know what a waste gate does? Mine only opens when I max boost, so it's open while I'm gunning it, then I shift, off the throttle so waste gate closes, compressor flutters then I'm back on the gas waste gate all open and screaming again.
Impossible to stop your turbo spinning, it may slow slightly but probably as much as a normal vta bov would between shifts. That vutututu sound is the comp wheel chopping through air, you do know your exhaust gas is spinning the turbo with far more force than what the excess air in the intake can manage to slow the turbo
It is also more efficient to run no bov and still have a large amount of positive pressure in the intake pipes than running a vta and having to build that boost again from nothing.
Your "knowledge" on how a waste gate works and how you can stop a turbo by running no bov makes all your opinions null and void. I'm sorry but you don't know ****.
Have you ever run no bov? If you haven't keep your opinion to yourself. Many cars from factory run no bov and most companies use a recirculating bov to keep the "unwanted" noise to a minimum.
Old Jun 27, 2015 | 08:55 PM
  #36
kaj's Avatar
kaj
..wow. Okay, you win.
Old Jun 27, 2015 | 09:40 PM
  #37
I'm not trying to win, I am just adding my part from real world experience.
Anyway.. Good chat
Old Jun 29, 2015 | 03:32 PM
  #38
twabtoxer's Avatar
Anyway.. Good chat
Hey! No giving up without a fight damn it!! Evom has been a little too quiet lately.
Old Jun 29, 2015 | 03:47 PM
  #39
LetsGetThisDone's Avatar
You absolutely have to run some sort of diverter or blow off valve, or you are begging to blow up a turbo. Without a blow off valve, when the throttle plate shuts, all of the air in the charge pipes has to go somewhere, either out the blow off valve (which you don't have), or backwards out of the turbo (compressor surge). In severe cases it WILL snap the turbine shaft. In less severe case it RAPIDLY slows the compressor while exhaust gases are still trying to spin the turbine, which puts a huge load on the bearing system in the CHRA, it can even make the turbo spin backwards momentarily.
The only vehicles that don't run a blow off or diverter valve are diesels that don't have throttles.
You are the one who has absolutely no idea what you're talking about.
Old Jun 29, 2015 | 04:35 PM
  #40
kaj's Avatar
kaj
One thing I've learned in my old age is to know when a conversation is going nowhere. LOL
No way, dude. You gotta keep the air in. Why waste it in the atmosphere?!
Old Jun 29, 2015 | 07:54 PM
  #41
Moksha's Avatar
Back to the main thread topic...
Stock 9 Bov ftw.. Sounds great and works well. The end hahahaa
Old Jun 30, 2015 | 09:20 AM
  #42
D Sizzle's Avatar
I know this isn't my thread, but im acutally tying to upgrade Bovs. I have a evo 8 and I hear that the 9s bovs would be a huge upgrade for me. is this true? I should I just go aftermarket?
Old Jun 30, 2015 | 10:44 AM
  #43
kaj's Avatar
kaj
They work well, last a long time, and won't break like the plastic ones on the VIII. they are non-adjustable, which is fine for most of us.
If you are planning to run a ton of boost, I'd probably go with aftermarket.
Old Jun 30, 2015 | 10:46 AM
  #44
BBYEvo82003's Avatar
9 crushed and HKS have worked well for me
Old Jul 1, 2015 | 03:34 AM
  #45
D Sizzle's Avatar
That works for me! I don't ever plan on going over 30 pounds. I'm gonna place my order with stm. Thanks!!!
