Replaced crank sensor, still a nostart condition.
Old Jun 19, 2015 | 11:25 AM
TreatsIX's Avatar
Balance shaft belt snapped and destroyed the crank sensor.
Took everything apart and replaced the sensor.
Left the belt off as I am unable to replace it at this time.
After reassembly the car will crank but not start. Battery was out for a week which reset the CEL codes but I expected another code upon no start. No codes showed up tho.
Thanks
Flip
Old Jun 19, 2015 | 11:47 AM
sujinX's Avatar
check ur timing belt and see if theres damage and if its still in time.
Old Jun 19, 2015 | 02:33 PM
TreatsIX's Avatar
Timing belt looks fine and didn't jump at all!
Old Jun 19, 2015 | 03:09 PM
barneyb's Avatar
Charge the battery. Check spark. If spark is yes then check compression.
Old Jun 20, 2015 | 07:56 AM
TreatsIX's Avatar
Battery charged, also tried jumping it!! Used a timing light and did not have spark, where now?
Thanks!!
Old Jun 20, 2015 | 08:27 AM
miragevo's Avatar
Veteran: Navy
Check #1 10 amp fuse in the fusebox under the left side dash
Old Jun 20, 2015 | 10:20 AM
TreatsIX's Avatar
Such a hard fuse to get to lol, ignition coil fuse? Looks fine swapped anyway but the issue remains
Old Jun 21, 2015 | 08:18 AM
TreatsIX's Avatar
Update bump,
Pulled a coil and realized I do have spark.
Pulled off the fuel regulator and I do have fuel.
Pulled a plug and there is no fuel in the cylinder.
Used a multimeter and the crank sensor is reading correctly.
Still looking...
Old Jun 22, 2015 | 09:58 AM
barneyb's Avatar
Originally Posted by TreatsIX
Update bump,
Still looking...
Pulling a coil and getting spark, well, you probably did the same thing the engine computer does and that is to interrupt current. Interrupting battery current is what creates spark.
Since the crank sensor got snagged I'd suggest checking every fuse in the car. These new fuses are easy to check since you don't need to pull them. But back to the sensor being snagged, I'd look upstream in the wiring harness, maybe something else got pulled apart.
Finally, I believe the ECU delivers spark and fuel off of the cam sensor, not the crank sensor. Well, they both need to be working for success.
Old Jun 22, 2015 | 12:51 PM
TreatsIX's Avatar
I did find a ground farther up in the wiring that had melted apart... The one near the coolant and cam sensor.
But wouldn't the can sensor throw a code if it was preventing startup?
Will fix the ground issue and report back.
Old Jun 22, 2015 | 07:17 PM
buzzzin_IX's Avatar
when your turn to start the car does it crank over or does it just click?
Old Jun 23, 2015 | 12:43 PM
TreatsIX's Avatar
Car cranks perfectly, I marked the timing belt and you can see it move.
Fixed the ground issue but it did not resolve the issue.
I really don't want to tow this to the shop ;(
Old Jan 25, 2017 | 09:06 AM
NJ9MR's Avatar
FCOTM Winner
Exclamation
PLEASE respond to my numerous posts, and 2 PMs. Thanks.
Old Jan 31, 2017 | 10:48 AM
EVOEvolved's Avatar
Any update?
Old Jan 31, 2017 | 05:30 PM
barneyb's Avatar
I think it got towed to the shop 1.5 years ago.
sk8terdude929
15
Nov 2, 2014 02:57 PM
_des_
Mar 8, 2012 07:56 PM
revvin9k
19
Jul 11, 2009 05:18 AM
hybrids14
Mar 19, 2007 01:06 PM
