Does Retune needed when going with 02 dump???
Old Jul 3, 2015 | 06:32 PM
Black_EVO_MR's Avatar
My car is already tuned making 355/330 with basic bolt ons but im thinking about changing out my aftermarket 02 housing with 02 dump.
Will I have to retune the car?
My guess is yes to get most out of it but if I don't tune it will it hurt the current tune?
Is 02 dump even worth it?
I will tune it later for sure once I do more mods but I just don't want it to hurt the power that the car is already making if that makes sense, thanks guys.
Old Jul 3, 2015 | 06:38 PM
Evoguy201's Avatar
If you just do an exhaust dump I would think you'd be just fine.
If you are talking about the intake for some reason, then yes you will need a retune.
I would just get all my parts then throw them on when I know im ready to tune.
Old Jul 3, 2015 | 07:01 PM
im with you on that and that's exactly what I've done before but its just right now its perfect opportunity for me to change it while im working on something and I have perfect access to change it now instead of doing it later.
aside from crazy loud noise how much HP would I gain? Im just debating if I even need it.
Old Jul 3, 2015 | 07:24 PM
Evoguy201's Avatar
Good question honestly its best to ask your tuner.
Old Jul 3, 2015 | 08:57 PM
e_kobz's Avatar
I picked up almost 20whp by making the switch from a Titek 02 housing to a Muse 02 dump. Also picked up torque and spool by eliminating the back pressure that a recirculating setup causes
Old Jul 5, 2015 | 01:15 AM
roach85's Avatar
If you are going with an o2 dump like the JMF one that still utilizes the IWGA then I would say no, you do not need a retune. If you are getting one like the MAP CompGate 40 that uses an EWG then you at least need a retune just to make sure your boost levels are the same. For optimal gains a retune would be wise though. When I was on stock setup with the FP Black my tuner could not go higher than 27psi without getting knock/detonation on 93oct. When I switched to the MAP CompGate 40 with EWG he was able to raise it to 30psi before knock/detonation. That was the only change I made.
MrEvo420
Aug 29, 2015 03:46 PM
xmaciek82x
17
Feb 15, 2009 08:23 AM
cinek
38
Aug 19, 2008 02:22 AM
SWOLN
Apr 2, 2008 02:23 PM
Blue Evo 8
Jun 2, 2006 08:44 AM
