Whining as RPMs increase
Old Aug 19, 2015 | 01:31 PM
KJS's Avatar
KJS
Had my timing belt done 3 months ago and I've had this whine ever since (OEM belts/pulleys - gates water pump):
https://www.youtube.com/watch?v=EMkZJuhc1bM
I checked the timing belt @ top dead center and its not too tight:
https://www.youtube.com/watch?v=KhlYboMDXFM
Alternator whine? Pulley? Anyone seen this before?
Most noticeable around 2-3.5k. Happens while driving and in neutral.
Old Aug 19, 2015 | 02:33 PM
egis's Avatar
I would remove accessory belt and try again .could be one of the pulleys.
Old Sep 1, 2015 | 04:38 PM
KJS's Avatar
KJS
bump
Old Oct 10, 2015 | 07:04 PM
KJS's Avatar
KJS
Removed the belts, rotated all the accessory pulleys and everything seems okay.
Used a mechanics stethoscope and it seems that its coming from under the power steering/AC which I think is the front case and maybe the oil pump?
How do you remove the front case?
Old Oct 11, 2015 | 12:07 PM
barneyb's Avatar
If it didn't whine before the belt and all that was done was the belt then ....................
Old Oct 12, 2015 | 02:16 PM
qsiguy's Avatar
Power steering can whine if it's low on fluid or has some air in the lines. Might want to check the fluid level to rule that out since you said it sound like it's coming from that area.
Old Oct 12, 2015 | 06:45 PM
azboost92's Avatar
Did you install secret supercharger so you can hear it whine?
Old Oct 13, 2015 | 06:32 AM
GTijoejoe's Avatar
"Whinning as RPMs increase"
My buddy had this EXACT same problem, turned out to be his girlfriend...
On a serious note, check your fluid level. My PS pump had a whine when my belt was a tad too tight.
eisnikesb
May 29, 2014 05:11 AM
atombomb33
Feb 23, 2010 08:25 AM
SlowCar
Apr 30, 2005 10:27 PM
Costas
Lancer Engine Tech
Dec 18, 2001 01:03 AM
