Evo IX hesitation under WOT?
Old Sep 15, 2015 | 09:07 PM
michaelanjolo's Avatar
Hey guys, so recently my Evo IX has started acting up and when I go WOT the car sputters around 20PSI and hesitates and won't push any further. The car is normally hitting around 25PSI. It's almost like rapid backfiring sounds, any idea's as to what it could be..? The car idles fine and drives fine until I go wide open and hit around 20 lbs of boost, then it hesitates and doesn't push any further even with the throttle all the way to the floor.
Old Sep 16, 2015 | 04:31 AM
evo8426's Avatar
Before anything else, have you completed a boost leak test?
Old Sep 16, 2015 | 07:43 AM
No i have not done that yet, but I've checked all couplers, hoses, and everything seems to be connected still.
Old Sep 16, 2015 | 09:27 AM
Biggiesacks's Avatar
do a proper boost leak test, then check your spark plugs. Also how are you measuring boost? Ive seen gauges go bad and people crank up the boost and hitting fuel cut.
BOOSTEZ
168
Aug 15, 2019 06:12 AM
OldManQuentin
Apr 4, 2014 10:31 AM
AmbideXtrous
11
Nov 20, 2011 09:17 AM
aschold
11
Jun 6, 2009 07:00 AM
biohazzard
Lancer Troubleshooting
13
Jan 6, 2009 03:55 PM
