Newly built motor misfire at idle
I'm having an issue with my newly built 2.0 liter 4g63 on my 9. The motor currently has about 200 miles on it, so I'm still in the break in process. My check engine light is on. I'm reading a code for P0011 for mivec timing. Could this be related? I replaced the check valve, the oil feed isn't leaking, and the oil control valve is operating to spec. I think it could be the break in oil. Car runs fine in gear, moving, etc. At idle it will start to misfire and I will have to bloop the throttle to keep it alive so it doesn't stall. There are new (gsc s2) cams now but the car was tuned previously for similar size cams before and is set to idle at about 1100 rpms. The gas tank is leaking, I think it's just the pump since it was replaced and seems to only leak when full. Before anyone says anything about contacting the shop, I live 16 hours away since I moved and another shop will be tuning the car when the break in is done. I'm trying to get to the bottom of my problems before I get it tuned. Ideas?
I haven't cleared or rechecked the codes since I replaced the check valve. I'm not having any mivec issues or noises so I'm working on it. I think the old cams were 272's vs my current gsc s2. It's hopefully just that. I also had an evo 8.5 turbo before and now have a 9 Turbo (long story.) Also this issue doesn't differ from outside temperature and although it's a bit worse during cold starts it happens both when the cars warmed up and when it just starts.
johnashton11
11
Sep 13, 2019 01:23 PM
bsh
41
Apr 23, 2012 12:29 AM
EVIL-EVO-8
10
Nov 9, 2009 09:54 AM
Evoovasti
Apr 9, 2009 11:24 PM
Davethewave
Jun 27, 2008 03:10 PM
