Jdm EVO bumper on EVO 9
Old Nov 7, 2015 | 04:16 PM
Exsubie22's Avatar
What's going on, I was curious if my Buschur exhaust will work if I decide to go with a jdm EVO bumper?
Old Nov 7, 2015 | 05:04 PM
kaj's Avatar
kaj
You will need to shorten the exhaust a few inches, otherwise it looks kinda funny.
Old Nov 7, 2015 | 05:32 PM
Kada__85's Avatar
Yup^^ or you can purchase the axle back portion from buschur that fits the jdm rear
Old Nov 7, 2015 | 07:36 PM
Exsubie22's Avatar
Can't you chop some of the pipe were it slips through?
Old Nov 7, 2015 | 08:19 PM
Kada__85's Avatar
I dont think so because then you'd be moving the mounting hooks back rendering them useless
Old Nov 7, 2015 | 08:37 PM
kaj's Avatar
kaj
It has to be cut between the mount tab and muffler
Old Nov 7, 2015 | 09:16 PM
Bmurray's Avatar
Sorry to thread jack, but my Turbo XS is supposed to fit pretty well according to the jdm bumper exhaust thread. The canister is touching the bumper though. Anyone know what I could do? I dont see a way to adjust the exhaust really
Old Nov 7, 2015 | 10:24 PM
ODUB's Avatar
Get an exhaust shop to cut/weld the exhaust to fit.
Old Nov 8, 2015 | 12:51 AM
Hotsauce101's Avatar
This should help you.
https://www.evolutionm.net/forums/ev...nt-thread.html
I have the Blitz exhaust and it sits quite well. I was going to have a shop shorten it but it looks fine. Just a little poke.
Old Nov 8, 2015 | 12:28 PM
Butt Dyno's Avatar
From: Why do they always call the Evo the Dark Side?
I have a Perrin stealth catback with the USDM bumper, and it comes with a 3-4" extender dealie. So it may work with the JDM bumper.
Old Nov 8, 2015 | 03:07 PM
Exsubie22's Avatar
But it will work? Just stick out the back a little further than with usdm bumper..?
Old Nov 8, 2015 | 03:44 PM
kaj's Avatar
kaj
Usually. Depends on how the muffler sits.
Old Nov 11, 2015 | 10:04 AM
DSMolition's Avatar
Its pretty easy to fix I just did it. Cut on where the slip joint is ( exhaust pipe side toward the front of the car) Get a regular muffler clamp. You can actually slide the muffler side inside the part you cut off and use the regular clamp to attach them together. Then attach a new generic hanger. They make them that only require a exhaust clamp to attach around the exhaust between the muffler and tip. you can use your original mounting bolts. Any auto parts store should have everything. just get under there and start messing with it and you will figure it out. After doing mine like this it was solid but for peace of mind I welded where my clamps where to make sure it wasn't going to move.
Old Nov 11, 2015 | 10:43 AM
Kada__85's Avatar
It'll work, but will stick out a bit. My buschur bullet exhaust stuck out a couple inches past my jdm rear and worked percectly until I bought the buschur sd muffler made for the jdm rear
Old Nov 12, 2015 | 06:31 AM
domenictoretto's Avatar
x2 - Just did the exact same thing as well. Pics for reference below:
Bullet for USDM:
SD for JDM:
ZanarkO
15
Jan 10, 2012 10:01 AM
Don Q
Aug 1, 2009 10:15 AM
Boost3dxEvO
56
Feb 17, 2009 08:28 AM
