Evo GeneralDiscuss any generalized technical Evo related topics that may not fit into the other forums.
Please do not post tech and rumor threads here.
So long story short i bought an evo with HIDS and it didnt have the switch for the headlight angle adjusters, i came across the switch with a parts lot and hooked it up and when i adjusted the headlights and the passenger side would stop on whichever settinf i put it on but the driverside headlight would continue to actuate up and down. Any ideas on how to fix it other than leaving it unplugged? Thanks in advance
ok here what you do take the front bumper off then take the headlight off you will see leveler motor then that runs to the headlight housing see if that came off sometimes it happens if everything in the place tell someone to toggle the level switch while you watch and see if the motor actually moving
