Help!!!!!I'm going crazy !!!!!!
Old Nov 30, 2015 | 08:51 PM
detroit pistins's Avatar
Forgot to mention, think of the "BISS" adjustment as cracking the throttle blade just a hair bit to allow for some air to bypass the TB..... you may wonder then why do we need to do this if the IAC can do it....well its another knob or control over areas where the IAC is out of range.
Hope that helps!
Old Dec 1, 2015 | 07:32 PM
Robin651's Avatar
I was thinking the IAC as well, but he mentioned he replaced the throttle body, so....
maybe something simple like a faulty temp sensor?
Old Dec 1, 2015 | 09:05 PM
Ksay3's Avatar
Are you running speed density or maf
Old Dec 2, 2015 | 01:33 PM
ajkevo8's Avatar
Maf
Old Dec 2, 2015 | 01:34 PM
ajkevo8's Avatar
Originally Posted by detroit pistins
This is how it works, when the throttle is closed, the only way for the motor to stay alive is by actuating the IAC via ECU to provide the necessary amount of air to allow for the engine to idle at a set rpm. So for every rpm target (900, 1000, 1100 rpm) the IAC should correspond to the correct needed amount of “steps” or openings you can say to allow the motor to “breathe”
When the rpm oscillates or hunts, the ecu will run a PID control (I think its PID type in mitsu) to correct the oscillation. Depending how aggressive or “lazy” the PID was tuned, you may feel a delayed response or aggressive swings like you are describing…. Jumping to 2k…etc
If we think the tuning is all correct, then the other thing that could throw things off is the BISS adjustments or a leak which u ruled out. You mentioned that you put on a new throttle body, its possible that the BISS on the new TB needs some adjustments. If you are familiar with what I am describing and can adjust it in your garage while this oscillation behavior is occurring, then you could resolve the issue.
IAC typically will relearn its locations (Park..etc) especially after a battery disconnect, when the key is turned on but while the engine is off. I think it takes a 2 secs or so to complete this learning. Someone could confirm.
Do you have access to another IAC valve that you could test?
GL!
Ps. Biggie is on the same track....
Thanks man i'ma check that out and get back to you
Old Feb 11, 2016 | 05:18 PM
ajkevo8's Avatar
I mess with the biss screw and problem still occurred
Old Feb 11, 2016 | 05:21 PM
ajkevo8's Avatar
GL!
Messed with the biss screw still nothing changed ecept for haveing a higher idol
Old Feb 20, 2016 | 04:01 AM
CahitGP034's Avatar
I have the same problem couldnt figuer it out yet :/
Old Feb 20, 2016 | 03:59 PM
EVOIX315's Avatar
have you try to spray carb cleaner? you said you used a smoke test to check for vacuum/boost leaks? idk if that would be the best way to tell. they don't usually put out much pressure . i think around 3-5 psi . sounds like an intake gasket leak
E-SPEC INDUSTRIES
Evo X Dyno Results
51
Sep 1, 2015 11:14 AM
evo4life400
Oct 24, 2010 08:36 PM
SilvrEvoIX
10
Apr 27, 2010 01:01 PM
EvolutionTime
Mar 26, 2010 07:03 PM
