My Greddy gauges are working!!
Old Mar 24, 2004 | 09:34 PM
silverEVO8's Avatar
Smile My Greddy gauges are working!!
After some problems, my gauges are working fine! I got the Greddy 52 mm electronic Boost and EGT gauges. The green lights look kind of neat and match the A/C and temp controls as well as the Alpine HU.....
Old Mar 24, 2004 | 09:44 PM
pickleknock's Avatar
DAMN that is HOT!!! soon my lancer is gonna need a boost gauge and EGT... is that a custom inster for where the radio normaly goes or where did you get that cluster?
Old Mar 24, 2004 | 09:47 PM
2SloEvo's Avatar
looks sweet! Do you have any daytime pics?
The greddy gauges look nice, 52mm seems like the perfect size too!
Old Mar 24, 2004 | 10:09 PM
ChrisS.'s Avatar
Looks good!.......now just to change that Bar to PSI and GReddy would have a customer.........
Old Mar 24, 2004 | 10:57 PM
evo81's Avatar
hottness .just learn how to read in bars Chris.
Old Mar 24, 2004 | 11:00 PM
TwoMix9900's Avatar
man that's jus very sexy...what HU is that?
Old Mar 24, 2004 | 11:05 PM
Delta00's Avatar
You mean you cant multiply 14.5 by 1.4 when your about to redline in 4th dodging through cars blowin down the freeway?
Old Mar 25, 2004 | 06:56 AM
silverEVO8's Avatar
Thanks, that's the Alpine 9813 HU. The mounting pod is a custom made unit. I was thinking about mass producing them but I have not had much luck in that...
Actually, all one needs to do is to remember where the equivalent bar reading to the max psi one needs to keep. I have my car running at 20-21 psi max, so I look for 1.45 bar.... The gauge is cleverly redlined at 1.5 bar or 21.76 psi, so that really works fine for my EVO. Besides, when your about to redline in 4th dodging through cars blowin down the freeway, you'd hardly have much time to even look at the boost gauge
Old Mar 25, 2004 | 07:04 AM
silverEVO8's Avatar
I had posted something like this before.... The HU face plate is off and a plastic "stealth" cover is in it's place
Old Mar 25, 2004 | 08:24 AM
Forbiden's Avatar
For the record GReddy gauges aren't in bar... they in Kg/cm^2. Which 1 Kg/cm^2 = 14.22 PSI.
Anyways, love my GReddy gauges too
Old Mar 25, 2004 | 11:04 AM
evomind's Avatar
what kind of probs did u have with the electronic gauges??
i too am having problems with my electronic gauges and dont know what the problem is....
Old Mar 25, 2004 | 12:51 PM
silverEVO8's Avatar
Only installation problems. The gauges are great I think I had a bad ground or power connection. Please recheck all your connections. You might want to try different sources for power and earth than those you are using right now....
Old Mar 25, 2004 | 01:11 PM
silverEVO8's Avatar
You are absolutely right! I'm embarrased to admit that I did not pay attention to the gauges and just ignored the fact that 1 bar does not equal 1 Kg/cm^2
19 psi = 1.33 Kg/cm^2
20 psi = 1.40 Kg/cm^2
21 psi = 1.48 Kg/cm^2
22 psi = 1.55 Kg/cm^2
23 psi = 1.61 Kg/cm^2
black_beauty
Jan 10, 2012 01:20 PM
Ph3n1x
Jun 26, 2006 07:29 PM
evo8forme
11
Aug 16, 2005 10:08 AM
lithe
May 20, 2004 01:58 PM
Forbiden
Mar 6, 2004 08:54 AM
