idle
Old Dec 23, 2015 | 08:22 PM
moyassine's Avatar
idle
so i recently got my car tuned and we are loosing tons of power on top end. i have a built 2,4 ltr. 280 cams. ported head. using an fp red jb turbo. what could be the problem here
heres my dyno sheet
Attached Thumbnails idle-12321617_573890249429382_3184175581771906922_n.jpg   idle-12389081_10156378574870445_858037183_o.jpg
Old Dec 24, 2015 | 05:29 AM
moyassine's Avatar
bump
Old Dec 24, 2015 | 05:30 AM
moyassine's Avatar
bumpppp
Old Dec 24, 2015 | 07:19 AM
egis's Avatar
You can't expect more power at 7000 rpm on stroked motor.looks good to me
Old Dec 24, 2015 | 08:10 AM
Turndown's Avatar
Veteran: Army
Yeah you're not really losing that much on top, and you're also using a smallish turbo so you can't really expect a ton on top anyways
Old Dec 24, 2015 | 09:28 AM
moyassine's Avatar
so im pretty much maxed out on this turbo?
Old Dec 24, 2015 | 09:37 AM
moyassine's Avatar
Old Dec 24, 2015 | 12:38 PM
Turndown's Avatar
Veteran: Army
I wouldn't say you're maxed out necessarily, but the FP red tends to fall on its face in higher rpm's with the 2.3's and 2.4's. Nothing to worry about really, just shift sooner
Old Dec 24, 2015 | 12:48 PM
Ev0ikon's Avatar
If you are in Denver CO that elevation will put a damper on your ability to make power compared to the lower-to-sea-level places.
Old Dec 24, 2015 | 01:23 PM
moyassine's Avatar
Thumbs up
so i should be happy with this for now and get a new setup, maybe a 6266 or borg s366
Old Dec 24, 2015 | 01:33 PM
Turndown's Avatar
Veteran: Army
I would have fun with it until you decide to go bigger. I will also be doing a TS 6266 with an FiTtonic setup on my 2.3. Should be fun, but until then I'll enjoy my EF4
Old Dec 24, 2015 | 01:46 PM
moyassine's Avatar
very nice. but doesnt 6266 takes a min to spool up
Old Dec 24, 2015 | 01:50 PM
Turndown's Avatar
Veteran: Army
With a 2.3 or 2.4 and twin scroll it should spoil before 5k easy
Old Dec 24, 2015 | 01:53 PM
moyassine's Avatar
spool at 5k shift at 7500 ;/
Old Dec 24, 2015 | 01:54 PM
Turndown's Avatar
Veteran: Army
If you get a good tune and a twin scroll setup you should probably see spool around 4500 give or take. That's what I've seen on here anyways
