o2 dump loosing power?
Old Jan 1, 2016 | 10:05 AM
e_kobz's Avatar
Originally Posted by IzzyRS
I have a buddy that has an Evo with an O2 dump. I think I could live with the noise, its not that loud (dumps under the car, not out of the hood). But I did smell some exhaust fumes in the car. Nothing that would bother me, but I don't want my son breathing that in. Is that common with all O2 dumps?
I don't smell anything on either of my evos when I dump. The air velocity traveling under the car pushes those fumes out
Old Jan 1, 2016 | 11:19 AM
nor11384's Avatar
FCOTM Winner
just gotta have the hvac to rec...but ok ok back on topic lol...isn't a drop to 22 psi too low? I understand the engine is more efficient and flows better now but I'm still trying to understand how it'll make more power even though it had such a drastic drop in boost...doesn't make sense to me...if I tighten up the wastegate arm would it help to hold better?
Old Jan 1, 2016 | 11:25 AM
LetsGetThisDone's Avatar
Go get the car retuned. Don't just add preload to the wastegate to turn up the boost. You're changing things that effect fueling and could effect the amount timing the car can take.
Old Jan 1, 2016 | 11:41 AM
nor11384's Avatar
FCOTM Winner
makes sense but my tuner says this is normal and doesn't need a retune...I deleted the pcv with the catch can setup and I'm waiting on an egr block off plate...I guess when I install it I'll do a boost leak test and try to get him to retune...you know something though? I think I haven't been doing boost leak test correctly...I made a tester but I just put air in it, cover it with my finger, and listen for leaks...I've been seeing videos of how with a gauge people pump in air in stages until they reach the amount they're boosting...I just pump air in without knowing how much I'm putting in...
Old Jan 1, 2016 | 12:08 PM
roni4g63's Avatar
What happened is you used to boost spike up to 29 psi instead of the 28 psi you were tuned for, so now, with a divided dump like the muse, there is no exhaust backpressure preventing the wastegate from opening at the right time with alot of effort. so it just slams open and dumps the excess boost, thats why you get that mod before you get your car tuned, i would reinstall your old one or just get a reflash from your tuner.
Old Jan 1, 2016 | 01:44 PM
nor11384's Avatar
FCOTM Winner
OK but like I said before...can the tuner do something to make it hold better with less taper? What can I do to hold a bit more boost? Car sounds great with o2 dump and all but it feels slower now...there's gotta be something that can be done...
Old Jan 1, 2016 | 02:01 PM
Turndown's Avatar
Veteran: Army
Talk to your tuner lol He'l be able to tel you if he can or not...
Old Jan 1, 2016 | 02:55 PM
roni4g63's Avatar
yes what he will need to do is increase your wastegate duty cycle little by little at each given RPM scale untill it holds the boost like you want it to do. its pretty straight forward, he also might need to mess with the fueling a little but i doubt he would if you're going to have it back on the same boost level, my advice would be to just wait and do more mods and when you're done get a retune, that way you dont waste your money and do it twice.
Old Jan 1, 2016 | 03:08 PM
oneonlywgs's Avatar
you need to be retuned for it...
+1
Old Jan 1, 2016 | 04:45 PM
nor11384's Avatar
FCOTM Winner
these are all good suggestions...I've learned a bit with this thread and thank you all for being patient and explaining...didn't know you could control wg duty cycle with stock ecu...I will install the egr block off plate and figure out the correct way to do a boost leak test and talk to my tuner...
Old Jan 1, 2016 | 04:53 PM
saxon's Avatar
the retune will require more fueling if you want to make the same amount of boost as before
Old Jan 1, 2016 | 06:38 PM
nor11384's Avatar
FCOTM Winner
more fueling how? I'm on stock injectors...like richer afrs or up the duty cycle?
Old Jan 1, 2016 | 06:50 PM
Bhsj13's Avatar
just talk to your tuner. who is tuning it?
Increasing IDC, which riches the AFR's. You likely won't get boost back to where it was. But it should make a bit more power regardless.
MrEvo420
Aug 29, 2015 03:46 PM
tripturboD
May 25, 2008 08:34 PM
kingkyle
Jun 21, 2007 07:55 PM
Whistling IX
Jun 12, 2006 04:05 AM
amigoni
Jun 22, 2003 01:34 PM
