Hesitation, Stuttering, Bad Fuel Pump???
Old Jan 3, 2016 | 09:01 AM
IzzyRS's Avatar
The pump has some relays its hooked up to, but you should just re-wire it since its a $20 mod lol.
Old Jan 3, 2016 | 10:12 AM
stefenboy's Avatar
Don't really want to hack up the factory wiring. But might pin out the fuel pump pins and rewire and pin it back into the connector. I need to do more research regarding this.
Old Jan 11, 2016 | 07:19 PM
stefenboy's Avatar
Just want to update everyone that might encounter this issue. Replaced with new map omni 4 bar and car is running good so far. Just a quick question for those that went sd. Did anyone drill the port larger? Or did you guys just swap the factory map sensor? I ask because I feel the hole was kinda small and can be easily clogged.
Old Jan 12, 2016 | 08:55 PM
IzzyRS's Avatar
Awesome! I just installed the new omni and its been working fine. A catchcan will help prevent clogging.
MisUnderStood
Dec 16, 2015 08:53 AM
Carloverx
14
Dec 22, 2011 01:00 PM
