Bad fuel pump?
Old Jan 24, 2016 | 05:24 AM
metallman's Avatar
Bad fuel pump?
So here is the story as i was driving the car started to lose power turn it of and when im trying to start it it goes to 2000 rpm and after 5 seconds it struggles to keep the rpm up but when i try to give it gas the rpm go down and finally the engine turns off i have changed the spark plugs same problem
Old Jan 24, 2016 | 07:17 AM
stefenboy's Avatar
Might be map sensor.
Old Jan 24, 2016 | 07:27 AM
metallman's Avatar
I have a power fc + commander when i was driving and was giving it gas it was boging but suddenly it boosted normally and again with the bogging
Old Jan 24, 2016 | 07:40 AM
evo8426's Avatar
I'd suggest getting rid of the power fc and commander.
Old Jan 25, 2016 | 03:44 AM
metallman's Avatar
Why is that i never had problems what do you suggest
Old Jan 25, 2016 | 12:08 PM
stefenboy's Avatar
You are on a dower fc setup. The factory evo ecm uses the map sensor and cam sensor to trigger the fuel pump relays. For me my map sensor was bad which caused alot of problems. Do you have a wideband? You need to keep an eye out for lean conditions and it is easy to test the fuel pump.
Old Jan 26, 2016 | 06:11 AM
metallman's Avatar
Its an evo 6 so i dosent have a map sensor but with the instalation of the power fc the guy who tuned the car canceled the maf sensor i dont know if he installed a map sensor also when i turn the ignition to the on position i hear a loud whining im guessing its the fuel pump but sometimes that whining is a little bit faint i have removed the fuel line from the fuel rail and put it in an empty bottle 0.5 litter i turn the switch to the on position and fuel came but to get the bottle to half 250ml i had to turn the key three times on and off fuel seams ok no water just clear gasoline.im wondering is it ok to put compressed air in a vacuum line to see if i have a leak somewhere
MisUnderStood
Dec 16, 2015 08:53 AM
Carloverx
14
Dec 22, 2011 01:00 PM
jaxjoker
Northwest Region
Jul 17, 2003 12:55 PM
