Holy Buzz Batman, reverberation at 4K RPM
If you can that would be great. Im not feeling any vibration. Its mostly the engine being loud.
Evo 8 driveshaft hitting exhaust flange - YouTube
I also have picutres of it all if needed
Alas, it sounds nothing like mine.
Not an answer to your problem but just want to say I feel your pain. I had a buzzing/rattle noise for the past 2 months when the car would get above 4k. It sounded like it was coming from the dash or inside the dash. It was very hard to pin point. I was doing my oil change and I put my light up on the part where the windshield wipers are and I noticed that the plastic cover was very loose. Secured it and it went away. It wasn't as loud yours though.
If I was you, go through your engine bay and underneath the car and wiggle things around before tearing into the engine. Good luck and let us know what you find!
Anyone who has had their timing off experience similar sounds?
He just replaced it with a new OEM one. My car sounds like this currently:
It still has more resonance than a engine with a balance shaft, but its so much better now.
Torque everything down, start with heats shield if you have one on , then turbo bolts, then go down the exhaust and check all the bolts are tight, I had a noise like that it was 1 bolt on the racing cat I had was coming lose.
Doesn't mean that there isn't a loose bolt somewhere though.
Z1 Performance
36
Sep 25, 2005 04:59 PM
