Gauge Increments to buy
Old Jan 28, 2016 | 08:45 PM
Jkuti13's Avatar
Im looking to buy new gauges and only have a wideband. Im at 714 whp on a dyno and pushing 32 psi with e85. I want to go defi becase ive heard great things and i am thinking the best are
1. Boost
2. Oil Pressure
3. Fuel Pressure
stop me if im wrong.
The thing is the boost gauge will be maxed out, i noticed defi had came out with a new "max-45PSI gauge" but i cant find it. Im not sure which specific increments to look for considering oil and fuel pressure. defi make a gauge for oil pressure specifically but not for fuel pressure to match the red racer gauges im looking at. any help is appreciated i just want a good matching clean setup that will be able to read all the most important stuff here. was considering an exhaust temp gauge too. going with a 3 pod for the dash btw because my WB is integrated into the cluster replacing the "lancer" circle.
Old Jan 29, 2016 | 10:09 AM
DSMolition's Avatar
Aem makes a 35 and 50 lb max gauge.
As for fuel pressure your car should idle at 43.5 psi and advance at a 1:1 ratio so I would get one that goes to at least 83psi (40psi of boost)
Old Jan 29, 2016 | 10:51 AM
Jkuti13's Avatar
Pro sport digital premium
Was checking out the pro sport premiums. Heard very good and horrible stories. They have all the gauges with the right increments where as defi only has a few in their production line "racer gauges". What's the best way to go with this lol
Old Jan 29, 2016 | 01:20 PM
LetsGetThisDone's Avatar
oil and fuel pressure are typically 0-100psi gauges. boost, something reads the max boost you plan to run
Old Jan 29, 2016 | 03:25 PM
TheBoz's Avatar
if you have BSE done get the 150psi oil pressure gauge.
I have never had a real use for a boost gauge, so unless you really need it I would use that spot for oil temp. I am also guessing that you have a wideband gauge.
I like the AEM gauges also, and make sure you get gauges that use an external sensor. You do not want to run lines back into the cab.
Old Jan 29, 2016 | 03:44 PM
Pal215's Avatar
I run a Defi Boost, Defi EGT, and AEM UEGO wideband. After realizing monitoring oil pressure is more important than EGT, I opted to replace it with Defi's Oil pressure gauge.
Last gauge I added was a voltage gauge in parallel with my fuel pump to monitor the voltage rise at the pump during acceleration. This one was just a small, no name, generic gauge.
-pal215
Old Jan 29, 2016 | 04:29 PM
Jkuti13's Avatar
Im going with a triple gauge pod for my dash to mount and i would prefer they all match. What do you mean BSE?
Old Jan 29, 2016 | 05:00 PM
TheBoz's Avatar
Balance shaft elimination
My cold oil pressure is over 100psi and high 80's even back up to 100+ at 9000rpm with 20/50 oil
Old Jan 29, 2016 | 08:36 PM
Jkuti13's Avatar
Alright I should be fine. I'm going with the prosport evo digital premium 60mm gauges. With either a center dash mount or the rexspeed dash mount that is positioned towards diver and closer. The psi will get maxed out since I run 35, but not all the time at least. Would be nice if they had 45 like defi
Old Jan 30, 2016 | 03:35 PM
Hotsauce101's Avatar
I currently have AEM Boost, AFR and Oil pressure on my A pillar.
Doing oil temp on the steer wheel colum soon.
GodRealm06
Jul 5, 2012 04:00 AM
tephra
19
Mar 2, 2011 12:41 AM
mrfred
Sep 19, 2010 07:32 PM
Drill_Sergeant
Apr 25, 2009 10:43 PM
