Can EGR delete be done with the head on?
Old Feb 7, 2016 | 06:29 AM
Tekniq's Avatar
Question Can EGR delete be done with the head on?
As the title states...
Old Feb 7, 2016 | 07:14 AM
egis's Avatar
Yes bc egr port you want to plug is on the intake manifold. Which way you wanna do it? Standart or from the exhaust port side ?
Old Feb 7, 2016 | 07:32 AM
Tekniq's Avatar
Doesn't the block off plate go on the back of the IM near the throttle body?
I didnt know there was 2 ways to block it.
Old Feb 7, 2016 | 07:40 AM
egis's Avatar
Yes it does that's why you don't have to worry about taking the head off.
Old Feb 7, 2016 | 09:03 AM
Lukelis's Avatar
Rimti klausimai
Old Feb 7, 2016 | 09:19 AM
kaj's Avatar
kaj
yes, a block off plate or you can tap/plug the hole in the head that lets the exhaust go into the intake mani. some of us prefer that route as it keeps some heat out of the IM. this obviously involves removing the IM, though, along with very careful vacuuming and use of grease to catch the shavings (unless the head is off the car).
all you need is an 1/8" NPT plug, if i remember right, and a tap of the same size.
Old Feb 7, 2016 | 01:25 PM
Tekniq's Avatar
Ok. ^ that's the only way I knew it was done.
I will try to research more.
evolvedevo91
Nov 29, 2015 06:10 PM
slowsrt4:(
Apr 2, 2015 03:40 PM
fireroasted
Aug 31, 2013 09:52 AM
nlp187
Jul 8, 2012 10:32 PM
