New Evo Owner
Old Feb 9, 2016 | 10:09 PM
Ajehoti's Avatar
Originally Posted by RinOne
Congrats on the Evo bro. Clean car!
Thank you it needs some love lol
So I'm looking to overhaul the motor and someone recommended the buschur motor build. I see so many choices of motor all the way to a 2.4 4G64 block. What is best option that won't cause complication. Best way to build head and then transmission/transfer case/differential? I'm guessing DSS for axles and driveshaft?
Thanks
Old Feb 10, 2016 | 08:52 AM
nor11384's Avatar
FCOTM Winner
transmission/tcase/diff you can send to shepherd or jacks trans and they can fix em for you if theres anything wrong with them but not cheap...motor wise theres a bunch of options out there...
Old Feb 10, 2016 | 12:24 PM
Ajehoti's Avatar
is buschur good?
how much would the three drivetrain components run for normal building to hold 600-700 hp?
Old Feb 10, 2016 | 03:54 PM
nor11384's Avatar
FCOTM Winner
the 5 speed tranny is fine...6 speed are rated up to 400 tq I think...tcase you prob need to upgrade the diff inside if you're gonna be launching and bigger bolts...read diff not too sure I'll let someone else chime in on that...
Old Feb 10, 2016 | 04:02 PM
Ajehoti's Avatar
That's badass that I don't have to upgrade transmission, fifth gear is notchy at times and grinds slightly if you slam it into 5th gear. I will be changing fluid.
Old Feb 10, 2016 | 07:31 PM
nor11384's Avatar
FCOTM Winner
what clutch?
Old Feb 10, 2016 | 08:22 PM
Ajehoti's Avatar
what clutch?
its currently a stage 1 exedy but would do a twin disc
Old Feb 10, 2016 | 09:06 PM
nor11384's Avatar
FCOTM Winner
exedy twin...good stuff...gotta get it for that kind of power...
Old Feb 11, 2016 | 04:08 AM
B Roharik's Avatar
Originally Posted by Ajehoti
is buschur good?
To answer your buschur question yes buschur is a great choice to go. Lots of high HP guys go with his motor so you can buy with confidence
Old Feb 11, 2016 | 09:56 AM
Ajehoti's Avatar
I was looking at FP black ball bearing, I see that it makes power but is it reliable and would it be more wise to go a different route ?
Old Feb 11, 2016 | 04:42 PM
nor11384's Avatar
FCOTM Winner
fp turbos are good but theres a bunch of good turbos out there...just depends on your goals...
Old Feb 11, 2016 | 06:54 PM
BoostNY's Avatar
A good idea is to plan ahead. Have a goal for what hp you want to achieve and build your modifications around that. The higher the hp the more supporting mods you'll need to reliably make that power. whether you want to run E85 is an important decision as well. If you want to go way beyond 500whp you'll need to upgrade the engine internals.
Good Luck and congrats!
Old Feb 12, 2016 | 05:07 AM
Ajehoti's Avatar
I was told anything after 400 the internals would fold. I honestly want 5-600 hp. I'm not picky at all. I was told Evo 9 turbos make mid 4's. In all honesty I really just want to make the car fun
Old Feb 12, 2016 | 12:48 PM
nor11384's Avatar
FCOTM Winner
eh...theres stories of stock motor making 600whp but for how long who knows...i would do head studs, cams, turbo and try for 500whp until it blows up which with a good tune it may be a looooooong time...prob have to be on e85 to make that but idk...ill let others chime in...
Old Feb 14, 2016 | 05:49 AM
HarcoEvo's Avatar
Welcome to the board. I am new myself and came from the BMW M-world. I sold my E39 M5 to get an Evo VIII.
Congrats on the purchase; parts are way cheaper here on the darkside.
