Help with power steering issue
Old Feb 22, 2016 | 02:51 PM
EVOIX315's Avatar
Originally Posted by 3gturbo
Wow EVOIX315 did you watch your video? So your saying turning the wheel will damage something haha funny click the video above first thing the guy says is to turn the wheel 10-15 times. The air in the system on the otherhand is a cause for concern. If you follow the Proper instructions you will not damage anything. VACUUM PUMP IS NOT REQUIRED FOR THIS.
http://www.club3g.com/forum/maintena...ing-fluid.html
the video is posted as reference, thats why said watch the vacuum part. i only suggested using a vacuum pump because just about all manufacturers are requiring this procedure to bleed the newer systems and i have been using it for a while now and works really good. only trying to help the guy out.
Old Mar 1, 2016 | 06:59 PM
evillancer06's Avatar
Veteran: Navy
So I did more testing and more testing and finally said enough is enough and I just changed the pump. Turns out it was the pump. Was not sucking fluid at all. Put the new pump in and instantly it started whining and bubbling and all sorts of good stuff. So at the end of the day....I got my power steering back. Thank god.
true4nae
16
Nov 10, 2014 09:50 AM
xXANCHORMONXx
Aug 7, 2014 08:23 AM
Jesussaves1
22
Aug 17, 2013 07:33 AM
versiontwo
Nov 24, 2012 04:56 PM
shapapu
Dec 19, 2005 04:16 AM
