New IAC installed, rough idle and wideband does not read
Old Feb 19, 2016 | 06:08 PM
mister1161's Avatar
Long story short, my IAC went out on my 03 and I got a replacement. After the install, my wideband was reading lean. I reset the ecu (disconnect the battery) but after that the cars idle was worse and was no longer reading anything on the wideband (only dashes) Would this require another ecu reset or will it just need time to dial the idle back to normal?
Also, would this effect my ecuflash tune in anyway?
Old Feb 19, 2016 | 06:47 PM
evo.matt's Avatar
Do you have more than two maps on your ecu? Disconnecting the battery will default it to the first map. Make sure you are on the right map
Old Feb 20, 2016 | 03:51 AM
mister1161's Avatar
There was only one map.
Today I will do a boost leak test to see see if there is any leak.
Vehicle336
Aug 31, 2017 06:22 PM
4ukc
10
Dec 7, 2015 02:33 AM
CeeKayy
39
Jun 17, 2015 06:25 PM
Graphic
Jun 16, 2012 11:45 PM
whitedemon
Jun 4, 2011 12:29 PM
