Transporting a motor
Old Feb 22, 2016 | 08:41 AM
thepoint4life23's Avatar
This may sound like a dumb Questing but here we go.
I'm working on pulling my motor out of the car right now. Since the shop that will be building my motor is less then 2 hours from me, I was going to just drive the motor up and drop it off. I'm I know i will pull the oil pan and all oil parts off the Motor, the head will be all belts and all that but i need to know what everyone thoughts on the best and safest way to transport the motor.
Thank for your time
Old Feb 22, 2016 | 09:08 AM
LetsGetThisDone's Avatar
If I'm transporting an assembled motor, I usually put it on an engine stand, and secure it in the back of my truck. If you're taking it down to a short block, just set it on its side and make sure it's secure and not going to move around.
Old Feb 24, 2016 | 05:04 AM
I guess i'm more worried about getting the motor home once its built, more info welcome
Old Feb 24, 2016 | 12:17 PM
Well, then the first sentence of my post is exactly what you should do.
Old Feb 24, 2016 | 12:50 PM
RallySport9's Avatar
strapping it securely onto a pallet also works good. obviously protect the surface and make sure its flat. I found this way works well since you can get a couple of friends to help lift it and safely put it onto a trailer or truck. the block is so light once removed from the head.
Old Feb 24, 2016 | 06:16 PM
J_Striker's Avatar
If you have a truck and don't have a pallet, you can just place it in an old tire and it will hold it pretty securely.
Old Mar 2, 2016 | 10:45 AM
You can set it on its side if you need to before its built?
sunrichmond
E85 / Ethanol
Nov 13, 2010 02:13 PM
miller121mx
E85 / Ethanol
14
Nov 8, 2010 06:03 AM
asdfasdf128
Jan 31, 2008 03:34 PM
EvoDaWayToGo
Mar 26, 2005 01:02 AM
