Another gauge mounting option!
Old Mar 26, 2004 | 02:50 PM
silverEVO8's Avatar
Exclamation Another gauge mounting option!
I fashioned this mount for my upcoming A/F wide band gauge. It fits the ashtray. The gauge I have there is an old Autometer Boost gauge that I dropped so it's bent on the rim and does not work, however it's ideal for a mock up....
Old Mar 26, 2004 | 02:51 PM
silverEVO8's Avatar
Sorry about the bad pictures.... I cannot post larger images. Here is a close up
Old Mar 26, 2004 | 02:52 PM
silverEVO8's Avatar
another close-up
Old Mar 26, 2004 | 03:01 PM
expl0d's Avatar
its gotta be dangerous looking down at your ashtray when your driving to see your boost Its different, but to much of a strecth to see my boost... A pillars are still the best designed.
Old Mar 26, 2004 | 03:58 PM
Forbiden's Avatar
He said the boost gauge was just for measurements. For something such as A/F I could see this being very efficient and clean. But whateva floats yer boat
Old Mar 26, 2004 | 04:35 PM
silverEVO8's Avatar
Well, whenever you take your eyes off the road there is an element of danger.... Have you tried taking a look to various locations? I agree that the pillar might be easier to see without taking your eyes from the road too much, but I'm not sure of it. Seems like I remember the pillar being as distracting as anywhere else.... Anyway, when I look at gauges, my attention from the road is diverted no matter where the gauge is located.....
Old Mar 27, 2004 | 07:57 AM
bishiboy's Avatar
I did the same thing for my EVC V control unit. I made it so I could remove if I wanted.
Old Mar 27, 2004 | 07:59 AM
bishiboy's Avatar
It's stainless steel sheet I got at Lowes. Cut and bent. Put 6mm vacuum line on the ends to hold in place, polished it and put velcro on to hold unit.
Old Mar 27, 2004 | 08:00 AM
bishiboy's Avatar
Here's a shoot with it removed.
Pretty simple but looks good.
SilverEvo8owner's Avatar
I was about to say
Why do you need two boost guages?
Old Mar 27, 2004 | 08:01 AM
bishiboy's Avatar
I have the EVC main unit and my HKS SAFR mounted in glovebox w/ velcro.
Old Mar 27, 2004 | 10:05 AM
silverEVO8's Avatar
Originally posted by SilverEvo8owner
I was about to say
The boost gauge in the ashtray is just for mock-up purposes (I needed a 52 mm gauge to make the mount). The gauge which will go there is the AEM wide band O2 controller display when it finally arrives.....
Old Mar 27, 2004 | 10:07 AM
silverEVO8's Avatar
I like it, it's simple and effective. Another good thing about is that's not permanent. I hate to drill and cut holes into the car.... I like the idea of something that's easily removed and leaves no trace.
