Lifters or Rod knock?
Old Mar 16, 2016 | 02:43 PM
Evogsr14's Avatar
I want your guys input on whether or not this tick/tap is the lifters or Rod knock
It taps under 2k rpms but after that no tick or tap
https://youtu.be/glKrYOdbIAk
Old Mar 16, 2016 | 03:58 PM
3gturbo's Avatar
Thats lifters it was a rod you would know it
Old Mar 16, 2016 | 04:38 PM
Teal2nnr's Avatar
Sounds like lifters. They are inexpensive to change out, so I would go that route and see what happens.
Old Apr 20, 2016 | 09:12 AM
evolord21's Avatar
Veteran: Army
lifters, had the same issue. its a pretty easy and inexpensive fix
Old Apr 20, 2016 | 09:31 AM
Biggiesacks's Avatar
There is actually a procedure for cleaning the lifters. You basically soak them in diesel fuel and pump them with the relief valve pressed in so fluid can flow through them. Basically like bleeding them but submerged in diesel. Then bleed them out and re-install. Also make sure you line up the hole on the side of the lash adjuster with the oil passage in the head when you re-install them.
thedru13
Nov 3, 2014 08:58 AM
tsidrift1
Oct 25, 2014 08:30 PM
ilikeppie
26
May 31, 2012 01:52 PM
Crester
Nov 17, 2010 08:09 AM
2k4EvoVIII
May 23, 2008 01:07 AM
