short shifter
Old Mar 24, 2016 | 12:56 PM
nor11384's Avatar
FCOTM Winner
short shifter
hey guys ive looked around and cant find much info about short shifters for the evo 8...theres a couple of threads but very old 08 - 12...seems like not alot of people use short shifters on these cars? is it worth it? any info on which is the best to buy? i know that they sell the shifter base bushings...are those worth it?
Old Mar 24, 2016 | 01:07 PM
hearnoevo's Avatar
short shifter
I use works but twm performance and b&m also make short shifters.
Old Mar 24, 2016 | 01:37 PM
nor11384's Avatar
FCOTM Winner
how do you like it and did you use the base bushings?
Old Mar 24, 2016 | 03:13 PM
hearnoevo's Avatar
short shifter
Works great, shifts are more precise and I have the base bushings as well.
Old Mar 24, 2016 | 04:56 PM
cudaman07's Avatar
no real viable option for the MR 6 speeds as far as I know. I heard a while back you could get it done at the Works shop itself but that they did not do mail out kits. Idk what you have, may not pertain.
Old Mar 24, 2016 | 07:46 PM
CJEvoIX's Avatar
Works ones seem pretty good, not much cutting/modifications needed.
Old Mar 24, 2016 | 08:50 PM
EMill's Avatar
I just upgraded my 5spd from the stock shift lever to a Works short shift lever. I liked the feel, but it actually shortened the height of the knob a bit more than I wanted, so I went out and got a taller knob. Now the knob sits a bit higher than stock, but the shift throw is pretty short because of the Works shift lever. For the record I also have billet bushings on the shift tower and it's purty darn notchy. Good luck!
Old Mar 24, 2016 | 08:51 PM
SW20Mike's Avatar
Veteran: Air Force
I use the B&M adjustable, adjusted to the shortest throw. Also have Buschur base and cable bushings. I bought the shifter used from a vendor on here, probably can't find them new anymore.
Old Mar 24, 2016 | 10:16 PM
alpinaturbo's Avatar
I have a Perrin short shifter that I took out of a previous Evo I owned: Perrin typically makes really nice products.
Shoot me a PM if you are interested, I just remembered I had it in garage for ages.
Old Mar 25, 2016 | 05:28 AM
nor11384's Avatar
FCOTM Winner
see that's what I'm afraid of...the notchiness...I don't mind the cutting and stuff...I'm pretty good with that stuff...works looks like a complete kit but a bit expensive compared to others...I haven't found much on the perrin shifters...all of the old threads seem to be about works, twm, and torque solution...
Old Mar 27, 2016 | 07:26 PM
Rolston12's Avatar
Just installed the works. Easy to install and good feel
Old Mar 28, 2016 | 12:14 AM
russian1212's Avatar
Do u have a link to the works shifter
Old Mar 28, 2016 | 12:31 AM
need_an_evo's Avatar
B&M Short Throw Shifter with metal bushings. Also have the Buschur under the hood bushings.Seems to do the trick.
Old Mar 28, 2016 | 12:33 AM
roni4g63's Avatar
Torque solutions has a kit, short shifter, underhood and shifter base busings all for like less than $130, i have this, shifts feel crisper!
Old Mar 28, 2016 | 12:39 AM
I had this on a previous evo 8 and I would say for the price and the quality you can not beat it.
