Hesitation start up please help
Old Mar 25, 2016 | 03:07 PM
DanielM's Avatar
Ok. When I start my Evo sometimes it starts perfect. Now sometimes mostly when it's hot or been sitting for 30 mins. I start it up and it idles crazy low and wants to shut back off almost as if it's misfiring bad, after 4 seconds the rpm actually climbs back up and idles fine after. Weird, Evo drives more than good. Has 272 intake and exhaust cosworth,880preccission injectors,255 walbro I believe. Any thoughts greatly appreciated.
Old Mar 25, 2016 | 09:04 PM
need_an_evo's Avatar
Throwing any codes? Sounds like IAC or MAP
Old Mar 26, 2016 | 06:02 AM
DanielM's Avatar
No codes other than a random misfire p0300. when I do drive with the ac on and I'm cruising around 40 ill clutch and put it straight to neutral the rpm drops fast and acts like it's going to turn off lights dim and all. . I'd have to let the rpm drop slowly by still being that gear.
Old Mar 27, 2016 | 05:51 AM
DanielM's Avatar
Could it be fuel related ?
Old Mar 27, 2016 | 10:55 PM
stefenboy's Avatar
Fuel pressure regulator, pcv / vac leak? Did you do boost test?
Old Mar 27, 2016 | 11:42 PM
DanielM's Avatar
Thanks I'll check the fuel pressure regulator and pcv tomorrow .. No vac leaks I'm aware of. I'll check the inter cooler piping tomorrow and make sure I'm no leaking. Hopefully it's nothing major. I did see one of my precission injectors have the rubber groomet cracked.
Ray521
Aug 29, 2015 06:58 AM
alsong2002
Apr 14, 2015 11:05 AM
JustAnoterEvo
Aug 15, 2013 03:05 PM
nlp187
Jul 8, 2012 10:32 PM
Hiboost
47
May 19, 2010 09:00 AM
