Evo X hesitation at start up
Old Aug 11, 2013 | 11:17 PM
JustAnoterEvo's Avatar
Question Evo X hesitation at start up
Earlier today, I went out to start my car and it took a bit before it started up. Probably about a good 5-10secs. Has anyone encountered this problem before? Its a 2013 and completely stock. i have about 4.6kmiles on it and this is the first time it had happened.
Old Aug 14, 2013 | 02:43 PM
timmy2754's Avatar
I have the same problem. sometimes it takes longer then 10sec to start. usually only happens with its really hot out. i just figure it is fuel pump relay....
Old Aug 14, 2013 | 08:41 PM
eclipsegsx012's Avatar
I have the same problem but I think it something to do with the ambient temp sensor. Next time when you try to crank and you have the same issue look at your cluster and the temp reading. It should read higher than what it should be
Old Aug 14, 2013 | 09:00 PM
MR. EVO MR's Avatar
Check the battery, my completely stock 2010 X MR's battery would uncharge by itself and would start hard too.
Old Aug 15, 2013 | 03:05 PM
The time it happened was at night for me so heat wasn't an issue there.
The problem didnt show itself again after about 3-4 days of driving it. It turns on normally now.
I have yet to check the battery. many people have told me it could be the battery as well. I will get it checked out once it does happen again or whenever i have time this weekend. Thanks for the advice everyone. I appreciate your inputs.
Landshark
Outlander Sport
Apr 4, 2017 05:23 AM
ant_turbo
Feb 9, 2016 06:31 PM
evolution13
May 15, 2015 04:33 PM
camMCLEAN
Jun 4, 2008 12:10 PM
EvoSam
Nov 13, 2005 06:36 PM
