Air bags deployed.
Old Apr 23, 2016 | 08:37 PM
Bzacharias's Avatar
Air bags deployed.
Ok I bought an 03 evo at auction that's pretty clean. But the air bags deployed. As far as I know now I have to replace the clock spring, driver airbag, and dash board. Is there anything else I need to replace? I seen a post on here saying the seatbelts, steering column, air bag module and some other stuff needs done. But to me those sound way to out there. Need a little input from someone who has done this. Thanks.
Old Apr 24, 2016 | 05:46 AM
There are a few theads here that discuss the items needed. If some of the posters are still active you can PM them if you have questions
Heres one: https://www.evolutionm.net/forums/ev...eployment.html
Old Apr 24, 2016 | 10:03 AM
Bzacharias's Avatar
I just need to know what's needed so the airbag light is not on.
Old Apr 24, 2016 | 10:16 AM
ElectricBlue's Avatar
Scan it, see whats wrong. Fix it.
Old Apr 24, 2016 | 03:51 PM
shavkatjon2000's Avatar
ok you will need a clock spring, front crash impact sensors, drivers air bag, passengers air bag and air bag ecu also seat belts if there is a code for them safety first
Old Apr 24, 2016 | 03:56 PM
Bzacharias's Avatar
How many front crash sensors are there? Anyone know what happens to the airbag ecu to need replaced. Thanks man for the answer I was looking for.
Old Apr 24, 2016 | 04:14 PM
Bzacharias's Avatar
Also for the airbag control module can I use any from a evo 8-9 or do I have to match numbers.
Old Apr 24, 2016 | 06:37 PM
Instead of asking a series of very technical questions, just Google Supplement Restraint system group 52B PDF (its downloadable)
Old Apr 24, 2016 | 06:57 PM
Bzacharias's Avatar
I did there isn't much for repairs. I have a pretty good idea what I need to do now
Old Apr 25, 2016 | 04:48 AM
there are two front crash sensors on the radiator support one on each side if you pop the hood open look at it you will see one yellow cable on each side when it comes to air bag ecu try to get evo 8 air bag ecu why you have to replace it once it records crash can't be used its like a black box you can send it out to get it reset but i would just buy a good used ecu with air bags not deployed after you get everything installed scan for codes and erase it and your all set have fun
Old Apr 25, 2016 | 08:47 AM
Bzacharias's Avatar
Thanks for the info.
Jrod@Buschur
Oct 5, 2011 07:57 AM
