Air Bag removal - after deployment?
Old Aug 20, 2009 | 06:57 PM
boomn29's Avatar
Had my airbags deploy last year and decided to turn the car into a track car. So, instead of replacing the airbags, the shop just cut them off and done.
So I'm trying to clean things up a bit and wanting to remove all the extraneous SRS airbag parts. I've read how to remove the airbag, but this is a bit different since it's been deployed...I think.
Once I pulled the steering wheel off, there is a a yellow wire ribbon that is still connected to the inside of the steering column. My question - what is this? What should I do with it? Keep it or cut it?
Old Aug 20, 2009 | 08:17 PM
xspsi4's Avatar
The yellow ribbon is your clockspring and you will need that for the horn I believe but just remove the 2 bolts in the side of the wheel and the bag will come out but you may wan't a new clock spring.
Airbag deployments in evos will need the following parts replaced
Dash
drivers bag
clockspring
steering column
seatbelts
windshield
and depending on the year it may need a new srs ecu
Old Aug 20, 2009 | 08:19 PM
xspsi4's Avatar
Btw once the drivers bag deploys the clockspring will need replaced or in your case just cut it since once it comes apart it is no longer any good.
Old Aug 20, 2009 | 08:25 PM
yahu's Avatar
Info should be here. Great site for DIY for our cars.
Old Aug 20, 2009 | 08:32 PM
Sievers's Avatar
I have a dash with a good airbag for sale much cheaper than you can get a new one for.
Pm if interested
Old Aug 21, 2009 | 05:31 AM
boomn29's Avatar
Yeah, I'm not interested in replacing it. It's mainly a track car now so it's just less weight!
I would like to have a horn back if possible. If the yellow ribbon is not part of it; sounds like I can trash it. I thought the black wire was the horn?
Old Aug 21, 2009 | 07:11 PM
xspsi4's Avatar
I am not 100% sure but the ribbon I know goes to the bag so I guess it would make sense that the bigger wire is for the horn.
Old Aug 22, 2009 | 09:24 AM
boomn29's Avatar
Here's how things look now.
Here's the pic of the wheel with everything removed. And the other pic are the spare parts. I wonder if I can make some kind of filler; maybe out of CF or something to fill in the hole? How do the RS wheels look there?
Attached Thumbnails Air Bag removal - after deployment?-wheel.jpg   Air Bag removal - after deployment?-wheel_spares.jpg
Old Aug 22, 2009 | 10:38 AM
abdizzle's Avatar
Dash
drivers bag
clockspring
steering column
seatbelts
windshield
I still don't understand why the steering column would need replacing? I've fixed 2 wrecked Evo's neither of which needed steering column's. This car is not German where it drops to prevent injury.
Also the SRS Module can easily be reset vs paying a fortune for a new one. Yes, even permanent fault codes from airbag deployment.
Old Aug 26, 2009 | 01:07 PM
Evoardo IX's Avatar
RS wheels are the same as yours used to be, RS version comes with airbags.
Old Sep 9, 2009 | 09:07 AM
BOOSTINAT30PSI's Avatar
my steering column broke upon impact... and it wasnt that hard of a hit. i wonder how expensive the steering column is to fix.
Old Sep 12, 2010 | 03:56 PM
dambreeze's Avatar
I have a similar problem with an 09 Lancer GTS. The only fault codes left after having replaced all necessary bags are for the seat belts, bumper sensor, and ecu. Can a module reset clear that as well, and how can I do that? Thanks so much for this great information so far. Oh, and my horn doesn't work as well
Old Apr 26, 2011 | 05:59 AM
kylemcritchie's Avatar
why do i have to get new seat belts? and how do i know if i need a new steering column or not?
Old Apr 26, 2011 | 06:47 AM
When airbags deploy... The seatbelts lock... Actually seize in the position they were in... So they cannot be re-used. (i wasnt wearing a seatbelt... And my seatbelts locked up and i couldnt pull them event with my kung fu grip!)
Old Apr 26, 2011 | 07:16 AM
even if you reset the computer?
