Random Wiring Harness - Unable to connect with tantix
Old May 14, 2016 | 03:37 PM
krypt952's Avatar
Hey guys.
I bought a evo 9 and I was trying to connect my tantrix cable into it to return the rom to the stock rom however when I try to connect with the tantrix cable it just does this
kernel get version
-- Ulocking ECU --
starting session...
requesting seed...
interface closed
Now that makes me think someone ether the ECU is locked (I know it has been tuned because someone forced on all the readiness monitors) or maybe an alternate wiring harness was installed
I looked under the passenger side glovebox and found the some of the harness has been clipped and other parts have been tapped into going to some kind of a sensor thats monitoring boost from a line that comes in from the firewall.
Also I found a 6pin wire loom that comes from somewhere up in the dash.
Attached are images of what I found any advice of what this 6pin loom is used for along with why someone would tap into the harness and if its related to my unable to connect to ecu flash would be appreciated.
Thanks
Aaron
Old May 15, 2016 | 09:54 AM
Biggiesacks's Avatar
here is a link to malibujacks's ecu unlocker tool http://www.aktivematrix.com/blog/wp-..._1-bugfix2.zip
krypt952
May 15, 2016 03:07 PM
ohthree
Aug 19, 2007 11:19 AM
EKsEvoate
Oct 28, 2006 05:26 PM
Warrtalon
May 30, 2006 04:51 PM
