Wheel Shaking When Braking Not Rotors
Old May 16, 2016 | 01:51 PM
80203's Avatar
I've replaced rotors and pads and am still having issues with the wheel shaking when I am braking and I can't figure out what the issue is.
I have properly broken in the new pads and rotors and had an alignment as well. Any suggestions on what else I can try?
Old May 16, 2016 | 01:54 PM
Epyon's Avatar
It could easily be something in the front suspension/steering, since braking would put a heavier load on the front of the car. Does your steering wheel shake as well?
Old May 16, 2016 | 01:58 PM
80203's Avatar
Correct, the steering wheel shakes even with slight braking its very frustrating the dealership coulnd't find anything wrong either
Old May 16, 2016 | 02:18 PM
barneyb's Avatar
What exactly did the dealership check? Just because the rotors are new doesn't mean they are straight. Just because they are straight doesn't mean they are sitting straight on the hub. Did they check for a bad wheel bearing or tie rod?
What brake pad are you using? Do you notice this more after hard braking? Was this occurring before you replaced parts?
Old May 16, 2016 | 02:29 PM
80203's Avatar
The dealership checked the suspension last time I brought it in for the airbag recall and my tuner installed the rotors and pads with me, he shook the wheel to see if it was a bad bearing but it all seemed ok. I haven't looked into the tie rod yet but that's my next move. Do you think I need to grease the guide pins and see if that helps?
Old May 16, 2016 | 03:18 PM
barneyb's Avatar
I never heard of greasing the quide pins helping this problem. I never grease them. Worth a try and easy enough to do.
I'd suggest looking for someone from whom you can borrow a dial indicator with magnetic mount and checking for run out. Limit for the rotor is 0.03 mm. Limit for the hub when pushing and pulling on it is 0.05 mm.
Old May 17, 2016 | 02:45 AM
WickedRSEvo's Avatar
Had the same problem. Do you have aftermarket wheels? If you do, you may need hub rings. I bought my car with aftermarket wheels, but no rings. I put them on and the difference was night and day.
Old May 17, 2016 | 05:00 AM
egis's Avatar
I had same exact problem with brand new rotors and pads. Turns out rear brake caliper wasn't squeezing evenly. Rebuilt all for calipers and problem went away.
Old May 17, 2016 | 05:51 AM
defibros's Avatar
I did the same. did all the calipers and the problem is gone as well
Old May 17, 2016 | 08:12 AM
80203's Avatar
Excellent advice thank you I will check the rear calipers I was thinking the issue was coming from the front of the vehicle.
Old May 17, 2016 | 12:49 PM
Jonno99's Avatar
Are the rims out of balance?
turbotaloon95
Sep 2, 2011 07:37 PM
AboodsEvo
11
Nov 28, 2010 07:04 PM
sliqdaddy91
14
Jun 24, 2009 05:07 PM
AhmadHasib
Sep 28, 2008 12:35 AM
Parikh1234
Apr 10, 2007 09:55 AM
