New clutch and flywheel issue
Subscribe
Jun 10, 2016 | 10:21 PM
Hi,
I just replaced my clutch 700 miles ago, and its been acting strange since the swap. I resurfaced the flywheel, and everything was replaced, such as: the clutch, pressure plate, and throw out bearing. Since the swap, getting the car rolling has been an issue. It would begin to slip, but i expected it to do so when originally installed. Now at 700 miles, and the vehicle is showing the same problems I am beginning to worry.
Reply 0
Jun 11, 2016 | 03:40 AM
after the new clutch installation did you do the clutch pedal adjustment and did you break in properly for at least 500 miles no boost normal stop and go driving if you look behind your clutch pedal there is a adjustment screw here is the link for it https://www.evolutionm.net/forums/ev...djustment.html
Reply 0
Subscribe
