What is this resistor for?
Old Jun 28, 2016 | 08:06 PM
JRally's Avatar
Firewall passenger side of an 8.
A mount plate holds a fuel pump relay, a resistor box with 4 wires for injectors, amd a third silver box with only 2 wires.
What is the 2 wire box for? #4 in illustration
Old Jun 28, 2016 | 09:00 PM
superbovine's Avatar
fuel pump resistor is the two wire one
Old Jun 28, 2016 | 09:56 PM
JRally's Avatar
Thank you for confirming.
Next big question though, can I jumper the wires and eliminate it since I'm running a Walbro?
I know in my Jeep days the Cherokees had these and we just bypassed them, they were only for pump noise reduction.
Old Jun 29, 2016 | 06:43 PM
Yeah its for low pressure operation under light load. People bypass it all the time, though I can't comment on the merits as I leave my cars with the stock configuration (even with walbro).
Search fuel pump rewire and you'll probably find some stuff on how to do it. You can ditch the resistor and the relay if you bypass it.
Old Jun 29, 2016 | 07:22 PM
hutch959's Avatar
the resistor is for the injectors. If you change the injectors you may need to bypass it depending on the type of injectors.
do not bypass it for a pump. It has nothing to do with the fuel pump.
Old Jun 29, 2016 | 07:40 PM
Biggiesacks's Avatar
if you bypass the resistor you are effectively removing the low voltage stage of the fuel pump operation. This could lead to fuel pressure regulator over run and shortened fuel pump life.
Old Jun 30, 2016 | 10:13 AM
JRally's Avatar
No, the injector box sits next to it and runs 4 wires into it. We've established that this is a resistor for the 9v operation of the fuel pump.
Yeah, you're right and this will be staying in the car until an aftermarket fpr goes into place and my double pumper goes in along with a direct wire.
Old Aug 28, 2017 | 02:05 PM
Talonboost's Avatar
Thanks for this info you guys. I've been looking for a decent pic or diagram of the part that drops voltage to the fuel pump for low load operation, and this is it.
peeps
Jul 25, 2011 02:28 PM
90GSX-03EVO
Sep 16, 2004 08:20 PM
DjDoubt
Lancer Engine Tech
39
Mar 14, 2004 10:06 PM
