Front door swap: should hinges be this tough to bolt up?
Old Aug 22, 2016 | 01:12 PM
raginghadron's Avatar
I had a fender bender that creased the panel on my front driver's side door, broke the door catch, and bent both of the original hinges and am in the process of replacing that assembly. I was trying to save myself the trouble of taking the fender off to access the hinge mounting holes on the body by attaching the hinges to the body first. It's proving nearly impossible to mount the door to the hinges this way because of tiny alignment discrepancies between the door, the body, and the hinge angles.
I'm at work thinking though things, and I'm starting to think that bolting the hinges to the door first and then removing the fender is the best way to save myself further headache. Can the hinge-to-body mounting bolts be accessed with the fender off?
Old Aug 22, 2016 | 01:20 PM
heel2toe's Avatar
Yeah I would pull off the fender and then get the door mounted aligned to the sideskirt a piller and rear door and then put the fender back on and lastly align that. Might be tricky to get the door on without removing the fender. With fender off the bolts are right there...
Old Aug 22, 2016 | 01:45 PM
That picture makes it clear that I was just chasing a dragon trying to avoid taking the fender off (resulting in 3 hours of swearing trying to get the damn thing on). Thanks so much!
Old Aug 22, 2016 | 01:54 PM
heel2toe's Avatar
Awesome glad I could help! I knew I had a pic like that in my phone so glad I attached it
Now get err done and back on the road!
Eve OH
Mar 18, 2016 07:50 PM
Yur
Jun 12, 2007 01:19 PM
04 evo
Apr 17, 2006 05:36 AM
Blevo
Sep 27, 2004 07:50 PM
ronitlancer
Mar 24, 2004 06:15 PM
