Can leaking water pump cause damage to timing belt?
Old Sep 26, 2016 | 09:14 AM
Womb Raider's Avatar
Veteran: Marine Corp
So my water pump started leaking not too long ago. I went ahead and ordered a water pump, just the pump because the guy a bought it from did the timing about 10k miles ago. The shop i took it too said i should do timing again because the coolant thats been leaking could of gone on it and it could ruin it and that i should just go ahead and buy the kit from them. Personally i think thats bull. When i look at the leak it doesnt even look like it gets on the timing belt. Looks like it just drips down onto the oil pan
Old Sep 26, 2016 | 09:23 AM
Pal215's Avatar
A coolant leak from the water pump would either get behind the timing belt or in front of it, not directly on it. The plastic timing covers should have also helped to keep coolant off the timing belt. The most I would do is spray everything down with MAF cleaner since it's sensor safe just to freshen things up, but I wouldn't change the timing belt especially if it has not been leaking for too long.
-pal215
There is internet conversation on if coolant can damage rubber belts & most note that it will not but should be washed off
I agree w/you that if the water pump was leaking out of the weep hole, it may not have contacted the timing belt but pull the timing belt cover & check if the belt is wet
Old Sep 26, 2016 | 10:55 AM
Okay, once i get it back from them i'll spray it down with some cleaner.
anthonypazsd
135
Apr 2, 2026 12:56 PM
evotris
29
Sep 8, 2013 07:26 AM
PSG Evo
16
Feb 6, 2011 09:28 AM
anthonypazsd
Jan 31, 2010 03:01 AM
Derek888
Jun 23, 2005 12:06 PM
