Wheel hop, clunk + rough shutter on take off sometimes
Old Sep 28, 2016 | 08:59 PM
maxspeed96ct's Avatar
So if I'm on a hill and ease the clutch out I get a wicked chatter and clunk.
Almost sounds like my exhaust is banging on the floor board but looking at it Underneith I don't see any clearance issues.
the brace the runs under the mid pipe is close, but not touching unless it does when torque is applied from the engine ?
The Car has a exedy twin which is normally smooth for the most part, it doesn't feel like clutch chatter cause I've had some rough clutches before, I have a Perrin downpipe.
I also did a launch from a dead stop and got some wicked wheel hop. I got out of it right away but it didn't feel good.
What at should I look at first?
Im guessing engine mounts but they look ok visually? Although the rubber could be worn.
I also get a bad clunk when I get on and off on the throttle in 5th gear.
any input ?
Old Sep 29, 2016 | 06:53 AM
Time to put this on a lift or a set of ramps & check the rear diff bushings. Possible rear diff clunk going on
Check the driveline mounts & the u-joints as well
sgambino92
May 27, 2018 07:30 PM
whitedemon
Jun 4, 2011 12:29 PM
YEVOVIII
May 11, 2005 06:51 AM
umiami80
20
Feb 28, 2005 02:50 PM
